Need Help! Upgrading B&O Speaker System!
MartianManiac
Cody
San Antonio, Texas
2024 Bronco Wildtrak ( Eruption Green )
I am not 100% confident in my understanding of our Stereo System, so please help.
2024 wildtrak with B&O
i have purchase ssv pods
kicker 6.5 x2 for kick panels
kicker 6 3/4 x2 for ssv pods
kicker 4 inchs for dash
denting
foam pads
but!?!
i want to purchase the kicker key 200.1 and dont know where to get the wire harness
i also want to custom subs and delete the stock sub… so anyhelp would be appreicated! Thank you!
hoel and plug and play kits say for (non b&O system )
Does Forscan void warrenty?
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
The B&O sound system is a 8 channel system. The Kicker 200.4 is a 4 channel amp. So… the math isn’t working out here.
So either you’re only going to amplify 4 of the speakers and leave the other 4 alone, or you need more amplifier.
I’d watch this video around the 4 minute mark. Explains the B&O system.
MartianManiac
MartianManiac
Cody
San Antonio, Texas
The dash has 3 speakers that are small enough to not need to amplified I thought. I’m really just trying to amplify the kick panel 6.5s and the new rear pods 6.75.
what would you recommend I do? Thank you for the reply!
RagnarKon
Bryan
New England
There is no plug-n-play kit to do that that I'm aware of. Two of the signals will come from the front amplifier, two of the signals will come from the rear amplifier.
So you will most likely have to custom wire it. Very possible, but if you've never done car audio before it'll be a learning experience for sure.
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
If you're doing components up front, and coax in the rear, you only need 4.1 assuming you're ditching the center channel. Staging is near impossible, so 8.1/5.1 doesn't make sense to me.
