Need help checking cv angle
Zhang
Gavin
Pittsburgh
Hi, I recently installed a lift kit on my bronco. Could someone tell me if this CV angle looks really bad?
Ford Bronco Need help checking cv angle 60DBB7B0-E78F-4449-8B0E-48793DA89DD1
Zhang
Zhang
Gavin
Pittsburgh
Ford Bronco Need help checking cv angle E1A2B709-D1DB-407C-8525-9E4E61B1C599
V1Rotate
Brevard, NC
2022 Wildtrak
What size lift/type of lift did you install? Doesn’t look like anything that would cause you issue IMO
Zhang
Zhang
Gavin
Pittsburgh
Eibach pro lift springs
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
It looks like the boot may eventually leak. See how the ribs of the boot look like they’re touching together. The friction will eventually tear the boot. In my old 4runner days, there were a couple options:
stretch the boot out so it doesn’t rub
replace the boot with a different design.
stretching the boot maybe the easiest option. You’ll have to do some research though.
Zhang
Zhang
Gavin
Pittsburgh
Thank you for your reply! I really appreciate it. Besides the boots, do you think the angle is acceptable?
Itchysquatch
Luke
Vermont
maybe someone on here who has experience lifting the bronco could answer. Other than the boots, that would have been an acceptable angle on the 4runner. I just don’t want to tell you it’s fine as I haven’t lifted my bronco.
flip
Phil
IN
www.ruxerparts.com
Fords
From the workshop manual.
Halfshaft
Special Tool(s) / General Equipment
Tire Lever
Removal
NOTICE: Do not hold the halfshaft by the CV joint.
NOTICE: The inner CV joint must not be bent more than 18°.
V1Rotate
Brevard, NC
2022 Wildtrak
Yes that angle is fine.. you’re not going to lift it and keep a stock CV angle, it’s just going to be what it’s going to be. A very rough estimate would be 10-12 deg based on your picture… Ford says good to 18. A sub 3” lift isn’t going to eat CV‘s on this platform
Ford Bronco Need help checking cv angle A92D4BC3-ACC9-4870-A786-AE3F96C6808E
da_jokker
Jeep Wrangler JKUR
I think the fix is the diff drop.
Silver-Bolt
Eureka, MT
What does the angle look like at full droop?
rtd16
Ryan
NY
2022 Bronco Big Bend
If you are really concerned I would recommend picking up an inclinometer and checking the actual angle. No offense to V1Rotate but it's tough to get an accurate measurement using a picture as there's a lot of variation into setting that baseline based on the picture (I tried that initially with mine and ended up being off). I have the same Eibach pro truck coil overs I'm assuming you do and have been chasing a noise issue for a while with no success. My driver's shaft measures almost 17 deg with an inclinometer and passenger at around 11-13. It's still within the factory spec as listed by flip but pretty damn close.
Zhang
Zhang
Gavin
Pittsburgh
thank you for your reply! Actually i don’t have any problem right now with my CV, and the angle is about 13 on both sides with inclinometer. Im just worry about potential problems and risks
Bikeric
Tulsa
2022 Badlands LUX on 37's
If all you have is the Eibach springs on the stock shocks you are guaranteed to be fine as you did not extend the length of the shock itself, you only made it run higher in its travel range (which Ford already designed for). If you had placed a spacer on the top of the shock it would be a different story. Your boots and angle look just fine in the pictures you posted.
V1Rotate
Brevard, NC
2022 Wildtrak
Yeah the picture is almost worthless if you need precision but I’ve found it’ll get within a few degrees if you take the time to do it from about 7 different directions and average them all together. BTW - is your noise you’re chasing after installing your coilovers a clunk when going over speed bumps by chance? If you have those adjusted all the way to the max (or close) and you’re riding way up in the useable range of the suspension you’re likely just hitting full extension way earlier than you ever would if you were in the middle of the range. If it’s unrelated - never mind. I’ve also seen adjustable track bar bolts be too long and hit the shock body in certain situations if you went that route. Just spitballing ideas
