Mysterious Black Box
lrb6805
Ross
2022 Bronco Badlands Sasquatch, 2006 Jeep LJ
I pulled the trim under the steering wheel and found this mysterious black box. I did not see a ford part number on it and looks like it might have been added at the dealership. It doesn't look right because it looks like a posi-tap was used
Does anyone have any idea what this is? Maybe lo-jack?
Ford Bronco Mysterious Black Box 64E5E5CA-B647-49C4-936B-28ED77671AF2
TTT
Alberto
Baja
Mustang Mach E Premium
LETs see the others bronco owners to take a looks if they have the same box underneath
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
I mounted my Kicker Key amp on the other side of that brace. That is not a factory item. No offense but did you finance at a high interest rate? They often put locators in such vehicles.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
Most likely a GPS tracker installed by the dealer, or a nefarious delivery driver. Check your purchase contract. If there is nothing in there about a GPS, disconnect that ground. Or take the whole thing out. That will drain your battery if hooked up to full time power. The 2 cut wires are likely ignition input for the white and starter kill for the green.
EDIT
Looks to be a Spireon Kahu tracker. Definitely installed by your dealer. Make sure you didnt pay for it. Looks like a lot of dealers add those with the mysterious $2000 mandatory protectant package charges. Definitely remove it if is not required by your finance contract.
‘21OBX
90Bronco19
2022 bronco outer banks
Def not on mine.
lrb6805
lrb6805
Ross
No, I got 2.79% interest on my loan. They had to have put it on even before I arrived. Once I got there to pick it up, no one touched it
Razorback
Dallas
Lincoln MKX
Dealer installed. Especially since there's no pigtail and just a power and ground wire. I've had mine opened several times putting in switch and fog lights and I have nothing mounted on that plate.
TXBoy79
Trevor
Lakewood Ranch, Fl
Ford F150
Did you purchase the Perimeter Plus security system? That’s what it looks like to me and I ordered it for my Bronco…whenever if finally ships.
