Broncobreath
Patrick
Hamburg ny
2022 bronco
Ok my next step in this build is going to be the white top. For those of you who are worried about the look of the white top, like I was. Try this…. I used printer paper and taped up a mock-up on the side and back of one side, to get an idea of how it will look. I have seen a few white tops in photos and wasn’t sure if I liked it. But when you see it in person, it looks so much better. So now it is off to the painter on February 2nd. 😁
If you don’t mind me asking, how much do they charge to paint the top?. I’m thinking of either getting mine wrapped in white or painting it white. Thank you
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
I had a friend paint mine so it was not bad. But I have heard it is about 3000. I would definitely do paint if you want it to last for the long haul.
Tylercrws
Tyler
Columbia TN
2022 Bronco
This is my thread on my 2 door Heritage build. As a 22 year old many years ago I had a 66 and then a 74 bronco. So when they announced the new Bronco I new I needed to reproduce an old classic. I started with a base 2 door automatic, In velocity blue. So far I have added a rough country 2” level kit. 1.something in the 2.something in the rear. And had custom built Wheelsmith wheels made. They are 17x8 steel smoothies, with 30mm offset. Interceptor caps with custom designed vinyl graphics. And modified old school fender badge with the “sport” removed. My next step will be the top painted in matching off white to the wheels. Should be done with that in a couple weeks.
Great build….do you have any side by side of the 2” lift before and after?
Once the prices get tolerable I’d love to wrap a MIC hard top in white for mine. Looks great!
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
Sorry I do not. That one photo is all I have of it in true base form. When I picked it up from the dealer it had the lift and tires on it
Broncobreath
Patrick
Hamburg ny
2022 bronco
Ford Bronco My velocity blue 2 door Base Bronco Heritage build. 380A941F-0101-4944-8B2F-F0D4D54EE463
Would you mind telling me about how much it cost to paint your hard top? Thank you.
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
It was very little because my good friend that owns a body shop did it for me. But I have been told it would be about 2500 to 3000.
Tunagates
NJ
hey man - great build! are those badges with the pins, just shaved them off?
timpyosito
Tim Breidenbach
Minnesota
2023 Bronco 4 Door Black Diamond
AARDVARK122, I see you now have the Falken 255/80R17 tires installed? Looks great BTW. I have this size mounted to Big Bend wheels for my soon to be here Black Diamond. I also have the 2" ReadyLIFT lift & level coil spacers ready to install.
Do you know the difference in offset between your 17×8 Wheelsmith wheels and the 17×7.5 Ford OEM wheels? I believe I may need BORA spacers to get the same appearance as your wheel set up.
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
Factory wheels are 55mm offset. Mine are 30mm offset. So basically 1 inch difference
timhood
Tim
Several
I'm ready for phase 3 of my Heritage transition and have been debating between a wrapped top, or (more likely) either painted or coated (like Rhino/LineX). How is the painted top holding up for you one year later? Any chips or flakes or other issues?
Ford Bronco My velocity blue 2 door Base Bronco Heritage build. 6EEBFA96-337B-4830-B61B-A919E4C2DE40
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
It has been great. No chips or peeling anywhere.
sgriffin911
Stacey
St George, UT
'22 OBX "Largo" + 7 other Fords 1964-2019
Ford Bronco My velocity blue 2 door Base Bronco Heritage build. 04B6DE26-A23B-4E78-9009-A310ABA5CC88
Looks like ours are related! Where in UT are you? So far I think there are 3 VB retro's here, that I've seen post.
~S~
