I got Badlands Sas. So steel for both.What bumper do you have?
Then I think you need to take a piece off of your rear bumper. Is that right everyone? Fronts you follow directions above.I got Badlands Sas. So steel for both.
That's spot on. On mine I had to take the small plastic filler off the back and the bolt holes were not in the same location. I had to make all new mounting holes for the rear as well, but it's just plastic so only took a momentFronts take about 20 minutes each. Rears go right on 3 screws each side. I used blue painters tape to trace the cut out needed for the Sas flare. Then cut them wide, meaning add a little extra flap ⅛" or so and it will fill the gap nicely. It's a 2 beer job.
So are these the ones you purchased and modified them to fit the Sasquatch flares?I got mine on sale from Stage 3.
Yep. Those Ford ones.So are these the ones you purchased and modified them to fit the Sasquatch flares?
https://www.stage3motorsports.com/m2dz-16a550-aa-21-22-bronco-ford-front-molded-splash-guards.html
What is holding on the front modified mud flap? I don't see any fastener to the sasquash flares? Did you use the L bracket?
