Stampede.Offroad
SD
junk
Jalisurr
Oklahoma
'09 Corvette Z06, '97 Mitsubishi Pajero Evo
Awesome find. This is very promising. Even 442ft-lbs gives a lot more headroom for the ecoboost V6es. Plus, crawler gear on a 7 speed sounds perfect for the Bronco. Very exciting.
Dirt
US
2016 F250
So @jjmtuttle was right? If so, we're also looking at 37" tires from factory and it's wider than the Ranger.
Stampede.Offroad
Stampede.Offroad
SD
junk
The gear spread on the Jeep 6-speed is 7.125, and the Ford 6-speed spread is 5.63.
A spread of 11 could give an impressive overdrive of .65 and still have a deeper granny gear (up to 7.15) than the current Jeep offering.
It begs the question that if the manual has so much potential for deep gearing, will the 10-speed automatic have a special Bronco gear set for comparable results as well? Will they be paired with a lower diff or transfer case ratio for street economy, or double down and match or exceed the competitions ratio for "crawling"?
Ford Bronco MTI550 7 Speed Manual Transmission With Low Crawler Gear Revealed in Document JL 6sp MT
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Excellent find / exciting / may be staying old skool
CJay
Chad
WI
'08 Ranger FX4 (MANUAL) & '74 VW Thing
Hybrid Manual 6 or 7 speed Transmission? Am I reading this right?
Ford Bronco MTI550 7 Speed Manual Transmission With Low Crawler Gear Revealed in Document 1583084068428
DrewBronc21
New York
I was hoping to tune the 2.7 EcoBoost which likely puts the torque over the rating but I would think it would probably roast the clutch before damaging the transmission so I’m sure Lots of people will push it to the limit and we will know what the real limits are if we get a manual option.
Stampede.Offroad
Stampede.Offroad
SD
junk
Happens to be just enough to handle Ford's 3.0L V6 diesel. 440ftlb and 250hp.
It was implied there was a larger v6 coming. The diesel with a manual (Jeep can't use theirs with a manual, the torque is too much) and that kind of deep gearing could be a very interesting combo. Put it in a 2-door and Jeep is one-upped at their own game again.
CJay
Chad
WI
Broncosaur
Bob
Connecticut
Good news, the electronics fans would have the Bronco slushbox only
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
Stampede.Offroad
Stampede.Offroad
SD
junk
At least we know the manual tranny will hold up when you armor the Bronco up to 8800lb or try to pull a 22000lb trailer.
Those figures and the 590lbft make this sound like it belongs in the Superduty Tremor too ...
