Morrflate Ten-Six air compressor
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
I am NOT affiliated with morrflate.
You can find the tech specs online.
I aired down my sasquatch to 15psi.
I aired up, all 4 35s at once, to 38psi. I have the DIY version of the Morrflate Quad
It took ~10 minutes.
It was warm at the end but cool enough to handle.
It wasn't very loud. It was about as loud as the 2.7 with the hood open.
All in all, I'm pleased.
Morrflate Ten-Six
VelocityBronco
E
I have the Maxi Trac compressor, which looks identical to this one, and it filled all 4 of my 33" tires with my DIY 4 tire hose system from 25psi to 39psi in about 4 minutes. It is quieter than I expected and performed great. I don't know how long term performance will be, but for ~$100 it doesn't matter a whole lot.
https://www.napaonline.com/en/p/BK_MTWM10215C
Both look like good options for portable compressors, and are probably identical, but different colors.
Scott R Nelson
Meridian, ID
I'm making my own 4-tire inflator/deflator - saving at least fifty bucks. Just waiting for Amazon to deliver the parts.
I went with a SmittyBilt 2780 air compressor which is NOT currently back ordered like the one in your link. Also less expensive.
I had to watch a lot of YouTube videos to get it all figured out.
kevin.gt
Kevin
Canton, GA
Looks like the morrflate branded one has psi cutoff. I’ve seen a few rebrandings of this same cheap compressor. Some have the cutoff, the napa maxi trac does not. Given the poor wiring in the maxi, I would definitely open it up and double check before trusting it
VelocityBronco
E
I saw a post where someone hooked up a pressure switch on the output. What is the concern, over inflating the tires? Should I be worried about not having a pressure cutoff or pressure switch?
Scott R Nelson
Meridian, ID
If you're going to start up the compressor and walk away maybe. I plan to be watching the whole time, so I don't see the point of having a cutoff switch.
VelocityBronco
E
Same here, I frequently check the pressure gauge and stay at the vehicle.
Ksjrb03
Tx
F250
Without the cutoff switch you need to turn off the compressor when not inflating, as obviously it will not shut itself off and blow your hose or nuke itself.
Scott R Nelson
Meridian, ID
Without the cutoff switch you need to turn off the compressor when not inflating, as obviously it will not shut itself off and blow your hose.
You make it sound like flipping a switch on the air compressor is difficult. It's not.
Captain nSANEo
Grand Strand, SC
Jeep Wrangler
Nice, I was actually deciding between them and https://www.speedflate.com/shop/air-systems as an inflate/deflate system. I ended up going with speedflate because I wanted to use the Viair system for its reliability.
BroncoOvrlndr
Charlotte, NC
Audi Q5
I watched the video and ordered the parts and modified the Napa Maxi Trac compressor I bought on sale for $89. I added the quick connect and the pressure shut off switch. When I took the cover off of my compressor the wiring was fine.
We just got back from spending some time at the Outer Banks and I aired down to 17 psi to drive on Corolla Beach to Cordova and saw some of the wild horses.
The Maxi Trac compressor with my mods for the pressure switch worked like a charm and aired right back up from 17psi to 39psi in about 2 mins per tire. All in I’m only @ $120 including mods so sure beats the price of a dual ARB compressor! Here’s a pic:
Ford Bronco Morrflate Ten-Six air compressor C42C7308-8162-4087-96FC-AF94E32EAC6F
And here’s a link to the YouTube video instructions how to modify:
Googz13
New York
Subaru Forester
The maxitrac is back in stock at napa for those waiting for one.
