Morimoto 4Banger NCS Fogs: Impressive
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Is the difference between the standard and HXB really worth the 200$ per light difference? Im going to order a set from you because i really like the idea of your harness.
It's a pretty big difference.
For example NCS Wide white are 144lux (14,400 candela) at 10m while HXB Wide white are 224 lux (22,400 candela).
Sooo not quite double but still more.
CliffordTheBigRedBronco
East Coast
So maybe worth it to get one Wide and one spot in the higher output. Does the order in which you pick the lights 1, 2, 3, change how they are arranged on the bracket or do you put them where you want them when assembling?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
No you decide where they sit when you install the kit.
