BuckeyeinNV
Henderson NV
4Runner
The Sasquatch package has extra lift compared to Badlands and still required limited up-travel to satisfy the engineers. Obviously 35s don't "fit" per Ford's manufacturing spec, which is zero percent chance of rubbing and probably a bit of buffer room. That's different than a regular person deciding that "fitting" means they don't rub in normal driving and only a little bit at full articulation.
BroncBro
BroncBro
2019 Tacoma 4x4
The Sasquatch package has extra lift compared to Badlands and still required limited up-travel to satisfy the engineers. Obviously 35s don't "fit" per Ford's manufacturing spec, which is zero percent chance or rubbing and probably a bit of buffer room. That's different than a regular person deciding that "fitting" means they don't rub in normal driving and only a little bit at full articulation.
Well, at least we now know there is a different height between the BL and Squatch. I would just like to know HOW? :ROFLMAO:
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Until they rub once or twice and you decide you just have to lift it a little more ...
BroncBro
BroncBro
2019 Tacoma 4x4
What the heck does that mean? Translated - I can’t answer your question.
Im taking that as possibly saying either they’re in talks about adding it due to popular demand and haven’t made a decision yet, or they want to wait and unveil some cool new options they haven’t released yet. Maybe, I don’t know. :LOL:
Lowcountry Bronco
William
South Carolina Lowcountry
Did they give any date on the color and material walk thru would be or is the b&p going to cover that?
Mcfly
LR4
4. Will rubberized floors be exclusive to the Black Diamond, Badlands, and First Edition?
Rubberized floors will only be available on Black Diamond and Badlands.
Are they saying First Edition no longer comes equipped with the rubberized floors?
Perhaps this clears up the discrepancy between the “Compare Models” pdf that states the FE gets carpeted floors, and the “Explore this model” which states FE gets rubberized floors. One is not correct. According to Ford above, it would appear the PDF is correct.
FE reserves are going to have a frenzy if true. Maybe I’m just reading too much onto their answer... but isn’t that the point?
Ford Bronco More Q&A from Bronco Super Celebration West (by multiple sources) 1849FCF8-21D5-4F3D-BD54-1CAEFD21A05E
And from ”Explore this model”:
Ford Bronco More Q&A from Bronco Super Celebration West (by multiple sources) FC3BF27A-4D7D-4F35-A211-0FDF0943D134
BroncBro
BroncBro
2019 Tacoma 4x4
It seems like it depends on which ford rep you speak to. I’ve read they are saying next week and another rep says later this month.
Corsair
Jacob
San Francisco
Escape
It never did.
BroncBro
BroncBro
2019 Tacoma 4x4
Under “Explore this model”:
I’m going to assume they were talking about options for the other models that have options.
Everybody knows what comes with the FE. And there are no options available for the FE. It comes with every available option.
kodiakisland
Arkansas
$600 into a loan payment is better than spending $400 out of your pocket money no?
No is correct.
Also, it will not cost $400 to do yourself unless you just want to spend that much.
