Monster Enclosed Sub - How to Solve Rattling
mdk77
BM
Illinois
Bronco Base SAS
I have a monster 10” enclosed sub in my cargo area. It is mounted to a molle panel. When the bass kicks in enough, the panel rattles. I’ve mounted the sub to the panel using a rubber backing and also used rubber bushings on the panel screws. That did not solve the rattling. I thinking the panel it itself just rattles when bass is loud. How have people solved this in their broncos? I was thinking a bazooka tube Velcro’d to the fabric
HotdogThud
mk6 gti, '21 MoarDoor
Needs to be mounted to actual bodywork, IMO. Something anchored to the rear floor would likely be the better option.
Just my two cents though, everyone's audio preferences are 100% subjective
mdk77
mdk77
BM
Illinois
Bronco Base SAS
Yes thinking the same. Trying to avoid drilling new holes though.
HotdogThud
Depending on how you do it, you could use the existing tie-down mounts on corners of the rear floor, those bolt right to the body.
