Modular bumper sensor hole plugs
Kevink820
Kevin
St. Louis, MO
2022 4door base
For the people that have swapped the modular bumper with sensor holes to a bronco that doesn’t have front parking sensors. Where are you getting your sensor hole plugs.
RagnarKon
Ford Bronco, Escape, Focus
I use rubber grommets for stuff like this. The kit I bought came from Harbor Freight and it looks like they don't sell it anymore. But they are all over Amazon.
I've also seen people at Bronco meetups with 3d printed versions they printed themselves or bought form Etsy.
HeliPilot
Kenny
CT
2022 2.7L SAS
I ordered a front parking sensor kit off Amazon for an aftermarket bumper I bought. The system has worked flawlessly for two years. You can see them in this closeup.
Ford Bronco Modular bumper sensor hole plugs IMG_0150
HD1976
Cleveland
2023 Bronco Black Diamond 4d V6 Sas
do you know the dimension ms of the grommet you used? I have a guy that can probably 3D print or make a vinyl wrap for the grommet using color if you want and maybe throw a Sasquatch or Bronco on it for customization. I send you some if he is able!
Ranbronc
Pa
Early Bronco
I bought a Rockhard 4x4 bumper it included plastic plugs in case you have a no sensor bumper.
measure the holes and check MSC direct or granger.
KABQ
Aaron
Albuquerque, NM
You could always buy a replacement sensor to model your 3D printed plug after so it will lock in position, then return the sensor.
