Mobridge - Non OEM Sub Install Help
NorthernSoul
Calgary/Boston
2021 Badlands 2dr
Hey all,
Installed the mobridge amp and will be replacing the OEM sub with an Alpine RS-SB10 in the back. If I want to use the wires from the OEM sub (Dual coil, 4 OHM) to my new one (single coil, 2 OHM) should I be joining the 2 positive wires (yellow/green in diagram below) as well as the 2 negative wires (purple/black) then hooking up? Appreciate any guidance here!
Ford Bronco Mobridge - Non OEM Sub Install Help 1719868518019-r
vicorjh
Jay
2023 Bronco Wildtrack
Hey all,
The Mobridge sub channels are bridged at the amplifier.
Single Coil Driver, don't need both pairs in this configuration but I use them anyhow for current carrying capacity:
Ford Bronco Mobridge - Non OEM Sub Install Help 1719869792465-fy
For a driver with dual coils, both channels are connected separately, in a similar fashion as the stock driver, instead of parallel as shown above. The resultant impedance would be 2 ohms at the amp for dual 4 ohm coils, as an example.
Dual Coil Driver:
Ford Bronco Mobridge - Non OEM Sub Install Help 1719869828057-z2
NorthernSoul
NorthernSoul
Calgary/Boston
2021 Badlands 2dr
Thanks for the speedy response. Fraser from Mobridge happened to call me as well and confirmed this is the right approach. Cheers!
vicorjh
Jay
Most welcome. Enjoy your new amp!
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Dual Coil Driver:
It's been a long time since I messed with subs and they were all DVCs and the amps I used were never bridged at the amp... For the OP's Alpine RS-SB10, it's noted the subwoofer's dual 4Ω voice coils are internally wired to present a 2Ω load at the spring posts.
I just ordered the JL Stealthbox and the Mobridge setup... Just triple confirming it's the same wiring scenario as the OP, as it appears the stealthbox uses a TW1-2 10" 2-ohm subwoofer, which appears to be a single voice coil @ 2-ohm, so I'd wire like the first diagram...
Ford Bronco Mobridge - Non OEM Sub Install Help 1720561093512-ja
Should these just be soldered together and then use banana plugs to connect the box?
BlarneyStoned
Apple-at-cha
Bronco, Land Rover
Yes.
The sub channels are already connected internally in the amp (e.g. mono only), just connect the + wires (11 + 13) and the - wires (12+ 14) in the harness for a stealthbox. If you had a DVC you could wire one set to each coil, but electrically it's the same as combining the wires - you're either splitting the current across terminals for DVC or all together for a SVC. This is how I ran my channels for a 3 way active front + rear fill + stealthbox:
Ford Bronco Mobridge - Non OEM Sub Install Help 1720568267433-rx
