Mirror Haze
TheJoshHarding
Josh
Columbia SC
2023 Bronco Outer Banks
So I spent some time detailing my bronco this weekend. I travel once a week mostly on a highway and I get a lot of bugs as a result. I used some bug and tar remover on those areas but I think I may have inadvertently wiped over the driver side mirror. As a result I’ve got a pretty good haze over it. It doesn’t seem like it’s scratched. Any thoughts on what I can do to remove and get back it’s clear luster?
Ford Bronco Mirror Haze IMG_6206
TheJoshHarding
Josh
Columbia SC
I’ve tried water at this point with no luck. Was going to try windex next but wanted to seek out some other opinions first
Vanimalious
Nicholas
Ford Ranger
Isopropyl alcohol? Don't know what the proper mix with water would be, but willing to bet it'll get that off.
Badsquatch2021
Chicago
Tbd
You can try wetting a rag in white vinegar let it sit on the surface for a few minutes then clean with a good window cleaner
RowsKing
JR
SJ
22 BRaptor, 66 Stang
CLR…… I use it on my bathroom glass shower doors. Gets everything off.
WheresMyBronco
Los Angeles
2023 Badlands
Just make sure you're careful with any method you use. The coating on the side mirrors can get burned through if you rub it too hard and will remove the reflective coating.
TheJoshHarding
Josh
Columbia SC
It seems like it’s some sort of residue—I tried a wet rag, and scratched at it with my fingernail. I;m debating on maybe taking a flat razor blade to it?
WheresMyBronco
Los Angeles
2023 Badlands
Hope I didn't catch this too late, because a razor will scratch the surface/coating.
KABQ
Aaron
Albuquerque, NM
Isopropanol first, if that doesn't work try ammonia, then try vinegar. Don't use a razor blade! The AR coatings on side mirrors can be pretty delicate.
TheJoshHarding
Josh
Columbia SC
Claybar (yellow, light duty, chemical guys) for the win! Thanks all!
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
Hard water mineral residue. It's very common around here.
