Mic Top Panel Storage Bag Silliness
Deleted User 5719102
Who's
On a Lake
22 2dr
Matching up the curve with the pads on the bottom of the bag, curve side matching. Drivers in first, cover and then insert passenger curve matching the bag. This worked great for me.
That panel bag is not the same as my 22 model, zipper configuration is different and you have patches sewn in each corner. Must be a 23 model change.
Karl_in_Chicago
Karl
Chicago
So there IS a payoff for those of us that had to wait almost 3 years! Thanks Ford. 🙃
Nabor19 thanks for all the pic's, very helpful. I'll be referring back to this once the weather cooperates for some tops-off driving. My first thought was to do it the same as the OP - insert the tops into the bag in the cargo area to minimize the risk of my clumsy ass dropping one on the ground. Still might go that way, at least initially, which could help validate if it's the method or some running change to the bags themselves.
HotRod76
HotRod76
Ryan
Tennessee
2006 Mustang GT
Yep, good catch. That is definitely different than the bag I have.
CyberOrangeBadlands
Joe
Long Island, NY
‘22 Bronco
Youtube knows all.
timstrong20
Tim
Georgia
2010 Toyota Venza and 2020 Honda Civic Hatchback
What type of mud flaps are those if you don't mind me asking. Also do you like them?
golfermurray16
Nathan
Charleston
Infinity QX80
I have a 23 and maybe it’s a different bag. Who knows. I was putting them in wrong for the longest time they would fit, but it wouldn’t zip. I was putting the curve on the bottom of the bag and the top of the bag then my son who is nine told me I’m doing it wrong! the curves go on the outside of the bag and they slide in and zip easily.
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
It's a tight fit, but it should be. You don't want those panels in a loose fitting bag banging around and possibly getting damaged.
Also, I get them in, I like to pick it up by the handles and shake it up and down a couple times like you would with a pillow case. It zips right up after that.
Nabor19
Minnesota
2023 Bronco Black Diamond; 1994 Corvette
They are the Amazon specials, but they mounted up great and I think really good. I figured for the $60 bucks I got them for, they were worth a shot. But they fit up really well and are sturdy. Make a big difference. They came with quick release hardware to slide off easily if you want.
WonVon Mud Flaps Splash Guards for Ford Bronco Accessories 2022 2/4-Door No Punching Required Front and Rear Quick Installation (4 pcs) https://a.co/d/g4oi6ud
Br0nc0_Badlands_Sasquatch
Drew
The Moon
N/A
I have a ‘22 and my bag looks the same. This reinforcements are only one side.
as for this thread, my issue is that my driver panel is starting to poke a hole in the top of the bag, it seems ford should’ve reinforced both sides of the bag
