MIC Hardtop Removal Solo?
_jonny_depth
Jon
Hyundai Sonata
I just received the email that my bronco is coming in by the end of next month. Has anyone seen or posted a video on how to remove the hardtop solo? I'm trying to figure out if I need to build some contraption or if its doable on my own without having to call a friend every time I want to go topless.
Wolfeman
Little Rock, AR
2019 F150 Raptor
Probably not the best idea to try and do it yourself. You might want to review some of the hoist options/ideas in the sub-forum below. I just purchased a Smart Garage Hardtop Lifter and am happy with it.
Here is a video of someone trying to do it with one person -
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
I don't think you can take off the shell piece alone, unless you were to crawl under it and lift it with your back. and have the strength of a bad ass. And even then, I'd be worried I'd drop it. You'll need a hoist ideally, or a buddy. The doors and other panels are easy alone.
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
watch youtube videos of removing the wrangler hardtop, then mimic that set-up.
What I did was found a cheap hoist on amazon, bought a couple 10'x2" lifting straps. Mounted the hoist in the attic.
Ford Bronco MIC Hardtop Removal Solo? 20220326_133344
Edit for picture
Its crooked b/c I hit it with my head prior to taking this pic
PatientlyWaiting
Brent
Marietta GA
MY22 Wildtrak
Wear gloves when you try to remove the middle panel by yourself. One side is like a razor blade. I learned the hard way. Had to get stitches when I was trying to readjust my grip after I pulled it off.
FstFrd00
2021 BD Sasquatch
I cut my middle finger, pretty good, on the edge of the front/right MIC panel
jasonkosi
Jason
Chilliwack, BC, Canada
Edit for picture
This is exactly what I’m planning on doing. Except I’m going to make a little cart out of 2x4s with some casters on it so the top doesn’t have to hang up the whole time it’s off. That way I can just wheel it to a corner of the shop and it’s out of the way
thatspecialbeat
Ryan
Meridian ID
Subies
I did exactly this. I would say it was sketchy at best but it worked without damaging anything.
Going to look into a hoist.
ocbucks1
Ron
CA
Toyta
You can search it on you tube. There are some examples of manual strap and pulley systems for less than $100 as long as your garage has vertical clearance of course.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I hear if you place some pillows and blankets behind your Bronco and floor it, the MIC top will come off pretty easily.
Disclaimer: Don't be a dumbass; don't try this at home.
codydb19
Cody
Silverado
As others have said it’s possible to get the rear cap off by yourself. But getting it back on without damaging the paint or the top itself is not something I want to try. It’s awkward to find and keep the center of gravity.
The Lange hoist a cart seems to fit my needs best (no garage) however no word if they are planning anything for Bronco or even if the existing system would work. I’m curious if I could just run straps like these DIY hoists are and use it that way.
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
I haven't seen a top lift that I would actually pay money for until this one. Wonder if they have one coming for the bronco?
