MIC Hard Top v2 Leaking
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
My 2021 2-door just started leaking from the passenger side MIC window panel. The hard top was replaced last summer via and I've not had any issues until this morning. it rained all day yesterday here and I noticed water pooling on the ledge by the window. I saw water coming dow the window from where it should be sealed. I don't want to take it back to the dealer because its just too much hassle. Can I just put in a small bead of silicone sealant and stop it myself? I don't have time to drop and off and wait days to get it fixed.
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Aeromech2284
2013 F150 FX4
I've got about 1300 miles on my 22 Badlands MIC that I picked up last month. I've got water coming in and leaking out of the driver and passenger side front airbags in the roll bar. Is there a TSB that applies to the 22? I'm not really happy that this $60k+ vehicle is already leaking water.
ahunter2
ahunter2
Austin
Tahoe
Believe there is, my service manager mentioned It at some point
buckwildtrk
Greg
Maryland
2023 Bronco
I am about to have the new seal replaced again and just like you said they put a ton of sealant on it to the point that it oozes out and looks like a home made job as you fixed it yourself. The dealer said that ooze is normal and nothing they can do to make it look better. Thanks Ford!
Cheers,
HD
I just got my 2023 2DR with a hardtop and discovered that it’s leaking as well. Just above the shifter so that water gets all over it and the console.
Jacoozzie
James
Wichita
Ford Bronco
Just the other day, went through a car wash and had my 2022 leak from behind the passenger sun visor. Never had any issues since it was purchased in September of last year. It's extremely disappointing for such an expensive vehicle
Ford Bronco MIC Hard Top v2 Leaking VideoCapture_20230802-100652
Ford Bronco MIC Hard Top v2 Leaking VideoCapture_20230802-100700
Jesman85
Toyota Highlander
I know this thread is old but I have had my 23 badlands for just over a year and both my rear mic top windows leak. Had it at the dealer today, they tested and couldn't reproduce the leak. Luckily mother nature stepped in and once I got it home it started to rain. After 6 hrs sitting in the rain, both rear windows are leaking from the top edge.
It's 10pm so I plan to take it in in the morning , but was your dealer able to resolve your issue? Did they just reinstall/seal them, and are you satisfied?
Ford Bronco MIC Hard Top v2 Leaking 1000004914
Update: Dealer basically just told me to go pound sand. Since the water has all dried up, they say they can't do anything. Photos and videos, they didn't even want to see as it has to be "actively leaking" for them to diagnose where the issue is. I get that to an extent, but there are drops of water on the inside edge of the MIC top around the rear windows... where could the water be coming from if not the seal around the windows?
I've engaged Ford Customer Support for what that's worth...
Atomic Betty
Abi
Vermont
VW Tiguan
Mine JUST started leaking this morning in the same place 😡 No issues since I picked it up September of last year (live in a cold climate so only got to take the MIC top off a couple times before winter hit, and only front 2 panels) but no issues all winter, through spring downpours, or touch free car washes. Then this morning turned into a road and water came out above the visor -what’s the heck??? I figured it was the MIC but checked all around when I got to work and nothing was wet there, then found a little plastic seam behind the mirror was slightly wet, I shudder to think what is behind the plastic cover 😞 Did you have any findings/resolutions? Thanks!
GaryB2220
Gary
Wellsboro PA
I have the same leaks. Took it to my dealer last month, they resealed the window and replaced "seals". It leaks way worse now, all the way to the drivers side, through my overhead lights and switches, onto my touchscreen and shift boot, etc.
Did anybody get this resolved? What was the fix? mine is back with the dealership again, its been over a week, and still nobody knows why.
Seems to me the best way to find out where the leak is coming from is to remove the internal plastic covers up overhead and dump water on the roof from the outside. See where its leaking in from
Atomic Betty
Abi
Vermont
VW Tiguan
So I don't remember experiencing any additional leaks and didn't take it in because I didn't take a picture when it was actually dumping out to show where the water was coming from, and then about a month ago I installed a Sunrider and SO FAR through all the drenching rains we've been having lately I haven't seen anything.........we'll see. 🤪 This makes me wonder if it's something with the panels?? I did notice the rubber on my panels is looking like it's already dry rotting so I've been attempting to contact my dealer, and their service department, with not much luck :cautious: I'll be putting the hardtop panels back on when the cold weather starts.
