MIC 2.0 replacement not acceptable!
BroncoAZ
Mitch
Mine is MIC 2.0 and it has some snakeskin and a rough edge over the drivers side window. Not the end of the world, but I think there will be a MIC 3.0 before long.
Ford Bronco MIC 2.0 replacement not acceptable! 2FF8A037-A7B5-412F-8A7B-227045429E97
Ford Bronco MIC 2.0 replacement not acceptable! 24652921-979D-4A38-AE27-8A70D77E6BC0
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Which should have been done by the dealer!!!
Should have been done by the glass installer. Could have been done by the dealer afterwards. Can still be done by the dealer or customer.
Unfortunately, none of those parties can fix unsealed edges, delamination, and snakeskinning of the composite panels. Only Webasto/FoMoCo can fix those issues, which was the overall purpose of the MIC 2.0 replacement program.
Seems silly to give up the advantages of MIC 2.0 over a cosmetic, excess sealant issue that can be quickly trimmed off by any competent Forest Gump with a razor blade.
Happy
Jerry
Missouri
CJ5, Wagoneer
Is the snakeskin issue ONLY for the outside or is the snakeskin on the inside also considered a problem?
BroncoAZ
Mitch
Not sure if it extends to cosmetic issues, but the function should be covered by my 8 year/100K Ford ESP warranty.
Bulldog5266
Appling
Fj cruiser
You are right- the 2.0 was promised to be
I didn’t see any of the promised 2.0 advantages- same unsealed edges with visible fibers that I have now, along with the sorry looking glass install. - no thanks! I’ll be praying something better comes along.
Ford Bronco MIC 2.0 replacement not acceptable! 6D9CE78F-B79C-4B68-9A9F-930D85FC30F2
bronco2drga
Nick
Georgia
2021 Bronco 2 Door
I have a two-door hardtop and this is above the passenger door, I have a big gap and if I put my flashlight on the inside I can see through it about a quarter inch. Anybody else seeing this?
21BL2DR
JD
ohio
2021 BL 2dr, 2021 BB 4dr, 2022 BS 2dr, trifecta
I don't think I would have gotten too worked up over sealant globs, but it's certainly true that many "MIC 2.0" tops are not living up to expectations. If the edges or snakeskin aren't improved over what you already have, you were probably correct to reject the top.
The tops are pretty bad, there's no sugarcoating it.
My 2.0 top is perfect in every aspect. Every 2.0 top I have looked at (about 10 now) have also been very very nice, with zero issues.
Ksjrb03
Tx
F250
Yup. stuff some foam in there and the wind noise goes down a bit too. Shocking.
Ford Bronco MIC 2.0 replacement not acceptable! B905FC63-81DA-48E1-8C6A-8F5811E85B34
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Still can't fix the ugly unfortunately. :(
21BL2DR
JD
ohio
My initial plan has always been to paint it either body color or black. I bought a Bestop fastback top for it also and in the spring will be putting it on my 2 door. I might be simply storing the hard top and leaving the soft top on. Time will tell.
iamchewby
Chewby
