MIC 2.0 leaking into A pillar trim
jclaypool83
PA
Badsquatch, 6.7L 2500 RAM, FOCUS RS
Every time I leave my 2021 Bronco out in the rain, the floor is filled with water. Anyone else have this issue? Seems to leak into the A pillar/vent and onto the floor.
Ford Bronco MIC 2.0 leaking into A pillar trim IMG_1023
Bronco21fan
Angelo
NewJersey
No issue with mine some are hit and miss undo the panels check the gaskets or just take it to the dealer there is a tsb for the hardtop
CJ1064
Clifford
Monmouth County, NJ
GT350, Cherokee
I have a similar issue just not as bad as yours. It just leaks at the very top, driver side, above the vent seem but only in heavy rain. I assume its from a bad seal on my hard top. But to be honest. My jeep leaked a little bit too so was to be expected.
CliffCo
Cliff
Charlotte
2021 Iconic Silver, Big Bend Sasquatch (MIC top)
I’ve seen that a little bit at the airbag panel at the A pillar… doesn’t do it much though.
da_jokker
Jeep Wrangler JKUR
Yeah there are multiple threads already about this. I believe there's even a TSB that Ford issued.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! Could you privately message us your VIN and the name and location of your Ford dealer so I can look into this leaking concern for you? Thank you!
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
Check with a Ford dealer. There is a service document about this issue.
Nym1178
Nicole
Maryland
I’ve got a 2022 bronco with this same issue. The dealership had a leak specialist examine the issue who said there is an issue. I have a part in order but done have an ETA in when I can get it fixed. For me it’s both passenger and driver sides. I’m glad I have the all weather mats.
Ford Bronco MIC 2.0 leaking into A pillar trim 3469C78C-B9BA-44D8-955D-12B8335CF599
Ford Bronco MIC 2.0 leaking into A pillar trim 541B6D00-815D-47D4-9B6E-5061621FB543
Ford Bronco MIC 2.0 leaking into A pillar trim 8F361406-6C1C-47EC-A175-6CAA8094C324
kodiakisland
Arkansas
Lots of threads and lots of vehicles with this issue. Mine never leaked until it did. Got it in November with no problems. Now I have the same leak. At least I don't plan to have the top on much anyway.
Nym1178
Nicole
Maryland
Just found the TSB and I think the dealership is using that to fix the leak.
Brianew
Seattle/Boise
69 Bronco, 08 Mustang, 2015 Wrangler
do you happen to have the TSB? my is leaking also :(
Nym1178
Nicole
Maryland
Here you go. The part just came in and is scheduled to be replaced on Tuesday. Fingers crossed that this fixes the leak.
dvdmnhn
CA
2021 Bronco First Edition
I've been having the same issue even after I brought my bronco in to have them smear a whole bunch of caulking/black silicone around the seams and still leaking, so I got a leaking top and silicone smeared all over the top 🤦‍♂️
Nym1178
Nicole
Maryland
Wow that looks horrible. They attempted to fix my leaks before this new safety recall came out and my dealership was much cleaner but I still have a leak much smaller but still there.
Ford Bronco MIC 2.0 leaking into A pillar trim A572D08A-21A6-46BB-AE36-677B611BE7EC
Ford Bronco MIC 2.0 leaking into A pillar trim 9B265502-6BC9-49E3-B01B-32B495CD7ADD
Ford Bronco MIC 2.0 leaking into A pillar trim AB974417-EA06-48AC-BD2E-1DFEEDCF2E66
Ford Bronco MIC 2.0 leaking into A pillar trim 15867E7E-8A54-4D13-80B7-2175553AA255
Ford Bronco MIC 2.0 leaking into A pillar trim B138F04D-67D7-4EE8-821E-86DC64C5CE53
