Method MR703 and Hub centric rings question
md1
VA
For those that installed Method MR703, did you also install hub centric ring and if so did you use the 106 to 93.1 or could you find 106.25 to 93.1? Did anyone forgo the rings and have you had any issues
Thanks.
BUCKIN6VA
Rob
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
I ordered these 93.1 > 106 following a recommendation from the service center: amazon.com/dp/B0BXWCDY5K?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5
I've noticed no difference.
shaw
shaun
California, Santa Clara
2024 Bronco
Thanks.
I've been wondering about this as well. From what I've read, plenty of people run the MR703s without hub centric rings and rely on properly torquing the lug nuts, but I'd still prefer using rings if the correct size is available. I'm curious whether anyone has noticed a difference in vibration or wheel centering with the 106 93.1 rings versus running without them.
