Method 701, 703, or 704
Which wheel on Sasquatch Goodyear tires (Carbonized Grey)
  • Total voters
    163
Brock9281
Atlanta
Need help deciding on the following wheels. Will be going on Sasquatch Goodyear tires and Carbonized Grey 4dr OBX Sas.
*Extra credit for pictures of your Bronco with any of these wheels
Ford Bronco Method 701, 703, or 704 DBB7CE3F-A984-4A13-8147-DF1FF35F1346
Ford Bronco Method 701, 703, or 704 0FEDD8D4-9DC7-4E1E-B6B2-FB9FA0D0CAB5
Ford Bronco Method 701, 703, or 704 758BB9D1-705F-41EC-8107-E5AE3183E5CA
carrellslake
Oregon
2022 Ford Bronco
If I ever get aftermarket wheels for my Bronco, they will be the 703s.
Brock9281
Brock9281
Atlanta
Can someone confirm this is correct for fitting Bronco?
Ford Bronco Method 701, 703, or 704 4DBB021D-8C70-400B-B5A4-63E4303D0E19
GToddC5
Todd
South Jersey
www.bronco6g.com
GToddC5
Todd
South Jersey
www.bronco6g.com
I revised my reply, so 5.5" or 139.7mm
Also, I think hub bore should be at least 93.1 mm. Lots of people are using the larger bore for Toyotas. It works, but keep in mind it's not hub centric, and you may want to buy adapter rings. Or not.
TXBoy79
Trevor
Lakewood Ranch, Fl
Ford F150
Are you stuck on matte black? Copper looks great on Carb Gray. There’s one local to me but I never took pics BUT…looked fantastic!
Damien21
Damien
San Diego, CA
2018 A4, 2013 Tacoma
I don't think any of these wheels come in the correct bolt pattern (6X139.7 / 6x5.5) to fit without an adapter, which is not ideal.
Blksn955.o
Greg
Wentzville, MO
the 701 and 704 spoke design or rim face is too flat or outwardly bowed. I like the 703 inward bow to the face as it gives a little depth.
I could have swore I saw a 6x5.5 but I know the hub size has been a issue as well.
BattleBornBronco
Jon
Las Vegas
2021 Bronco Badlands
705s… with +35 offset. Lightest trail series with highest available offset. Unless you are running 37s or 35x12s or wider, they would work great.
Dave-O
College Station, Tx
F-150/Mach-E
No love for. 705’s?
mbagne
Placentia, CA
Mach-E GT
I was looking at these Method 315's, will they work? Badlands/SAS.
Ford Bronco Method 701, 703, or 704 Method 315's
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
704's only because that is what I am getting. 😀 In Titanium
