Manual Badlands SelfSquatch
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
So I have a manual 2 door badlands with the upgraded wheels on the way.
Just ordered 35x12.5R17 Toyo ATIII's, and the 1" Rough Country level kit.
I'll also be putting 1/4inch wheel spacers to bring the wheels out a bit.
I think it should work..... What do you guys think?
kodiakisland
Arkansas
I think the wheels spacers aren’t needed. Not into that “look”. Should be fine otherwise.
Designkid
Kris
New Jersey
2021 Bronco Badlands
Are you keeping the stock wheels? Then you might need the spacers to clear the bigger tires
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
Yea, stock wheels. They are the Beadlock upgrade wheels. I love the look but need more offset, therefore the spacers.
cbrownabq
Littleton, CO
Dodge 2500 diesel
Oh man! That is gonna look sweet! That’s my ideal build. Please post pics.
Crowza
West Virginia
2023 Badlands 2 Door, '05 Victory Vegas 8-Ball
I would love to hear your opinion on the power difference, if it's even noticeable. Also, a before/after MPG comparison would be interesting as well.
..and pictures. Lots of pictures. :)
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
My main concern was the 315s clearing the Upper Control Arm with the stock +55 offset BL wheels, but it sounds like you’ve got that covered.
It’s worth noting that Sas is slightly taller than BL, so it won’t be identical, and you may experience rubbing at certain points (aside from extra height, Sas has decreased travel to accommodate 35s)…
…but that’s all stuff that doesn’t come into play except for the extreme use cases.
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
Oh there will be pictures! I just need my Bronco first! I'll be posting lots of pics on my instagram when I get it.
I think SAS is .6" higher than Badlands. My 1" lift will actually bring it .4" higher than a sasquatch. Hopping that will be enough.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ah! The lift. Yep. Missed that. Cool. Send it!
If you get a second, when you’re doing this can you just dry fit the 315s on +55 without the spacer?
There is a post on the forum sharing a FB post of someone who said they did just that without interference with the UCA. They insisted they were 315s on +55, even though our calculations here wouldn’t allow for it…. And I’m just thirsty for more data from a reliable source.
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
I work at my dealership so I can definitely do that. I'll take pics for sure and post them here.
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
Interesting post. This should definitely work. I didn't realize there was a level lift for the Bilsteins.
I was hoping/waiting for 2"level lift, but it seems like that's gonna require a lot more parts to adjust the geometry. Is that the consensus, or should I wait?
If this 1" front is all we are gonna get, I may follow your lead. I have zero offset wheels ordered, but delayed. I've been holding off on tires until someone else stuffed 35s under a non-sas Badlands.
But this 1" level lift plan is an answer. When are you expecting your rig? I'm currently an 8/9 build week.
I now can spend the rest of my day picking out tires. Work hates me.
Uintafly
2013 Tundra
I was under the impression that a level lift would cause issues with the Bilsteins. It will be nice to have a year or so under our belt so we have a ton of real world data.
BlueBronco
DFW
Agreed. I think you will need a 1" wheel spacer which will put the optional BL wheel offset about the same offset as the Squatch wheels. You may be able to get away with less but I don't think 1/4" will be near enough.
The more I read, the more I am leery of a spacer lift on a BL or Squatch. 4wp recommended against it so I would be cautions and not go bigger than 1". If somebody makes a 1/2" I would consider starting there.
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
The more I read the more I am leery of a spacer lift on a BL or Squatch. 4wp recommended against it so I would be cautions and not go bigger than 1". If somebody makes a 1/2" I would consider starting there.
That rough country 1" level lift that says it is ok for badlands has spacers for the top and bottom. The top have two spacers on each side, so you might be able to add just one and get somewhere between 1/2" and 1".
And I also agree you need 1" wheel spacer if you have +55mm offset wheels. The Sas wheels are 30 offset. 55-30=25mm and that converts to 0.984". So an inch.
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
Mine was built on 7/13..... but it's a two door and I feel like it's being held back for the MIC top.
