maintenance tips for any new Bronco owner
hammonton NJ
broncos
After owning a Bronco for a few years, I've compiled a list of maintenance tips from experience and googling issues that I've had. Any newbies to owning a Bronco or veterans with more tips to share are Welcome. Some of these are more of roading tips for the more extreme Bronco owners among you.
  • Include the Spare in Rotations: If you have the Sasquatch package or a matching 5th wheel, perform a 5-tire rotation. This prevents the spare from dry-rotting and extends the life of your expensive off-road tires by 20%.
  • Check Differential and Transfer Case Fluids After Water Crossings: Standard service intervals don't always account for off-roading. If you've submerged your axles in water or deep mud, inspect the fluids for contamination (milky fluid) to prevent severe gear damage.
  • Adjust Tire Pressure Off-Road: Your door-jamb sticker lists pressures for highway driving, but airing down to 15–20 psi off-road drastically smooths out the Bronco’s ride and protects your suspension and tires from punctures.
  • Tighten Your Tailgate Spare Carrier Bolts: The weight of larger tires often causes the tailgate hinges and bolts to loosen, resulting in squeaks or rattles. Periodically check and torque these bolts down.
  • Reset Your TPMS Automatically: The Bronco's tire pressure monitoring system is self-learning. If you frequently change your tire pressure for trail riding or air back up, you don't need a tool to relearn the sensors; they will automatically recalibrate after a few miles of driving
  • Lubricate the Soft Top or Hardtop Seals: Use a silicone-based lubricant (like Krytox or Ford's recommended spec) on all rubber weatherstripping. This prevents the seals from drying out, sticking, and causing squeaks or water leaks.
  • Service the Cabin Air Filter After Off-Roading: Dust storms and trail dust clog this filter much faster than normal driving. It is located directly behind the glovebox and requires no tools to swap out.
  • Monitor the Battery State of Charge (SoC): The Bronco is packed with electronics that draw power even when turned off. If you do not drive it frequently, use a AGM-compatible smart battery tender to prevent the vehicle from disabling deep-sleep features.
  • Check the Intake Pre-Air Cleaner: The air box has a small water drain trap and a pre-filter area. Check this area for leaves, mud, or trapped water after driving through heavy rain or deep mud.
  • Bleed Trapped Air from Brake Calipers After Heavy Trail Work: If you frequently use Trail Turn Assist or ride the brakes on steep declines, the fluid gets incredibly hot. Flush or bleed the brake fluid early if the pedal starts feeling spongy.
  • Inspect the EcoBoost Spark Plug Gaps: If you have the 2.3L or 2.7L EcoBoost engine and notice a minor rough idle, check the spark plug gaps. Turbocharged engines are sensitive to plug gaps, which can degrade slightly before the recommended service interval.
Never had an issue with needing to bleed the brake fluid. Rest of the list isn't bad. For tailgate bolts - that really applies to ... everything. Paint torque marks are a lifesaver here, particularly for suspension.
Mostly - just change the engine oil early and often, and use a full synthetic. Do the engine air filter with that. I do 5k miles. Inspect everything underneath when you do the oil change (look at the paint torque marks), and rotate the tires around the same time.
Plugs seem to last well, but many people (including myself) noticed an improvement in idle changing them out early.
23OBX2.7
AB Canada
2023 Bronco
I'd say if your driving super hard and fast stressing the machine your points are good OP otherwise it's overkill unless just enjoy wrenching like me.
A hipo dirt bike is high maint....
ODuckNo
Huntertown, IN
'25 Ford Bronco SAS
Change your motor oil early. Get wear particulates out. I did mine @ 500. , 1500, then 3000. Also did transfer, transmission (PPE pan added), & diffs around 3000. If you know you know.
Gopher
Stroppe
Kyle
69 Mach I, 70 BOSS 302, 17 Shelby GT350
Stroppe
Wow I thought I am anal about new-vehicle maintenance. You put me to shame! Overkill? Probably. Peace of mind? For sure!
off_road_ranger
hammonton NJ
broncos
I do tend to be a bit overkill on the maintenance, but I also enjoy wrenching on my Bronco, I'd also like to mention I just got a new set of tires, and I'm extremely pleased with them. I got a set of general grabbers to be a sort of daily/medium off-road tire, and they've held up great. I got them from an online site called Simple Tire, and I'd highly recommend them for anyone in need of new tires. Good customer service, impressive selection, and they have all of the specs, ratings, and reviews you could need I was very impressed def gonna keep buying tires from them. Keep the maintenance tips coming!
