Tippster
Tom
Seattle
Audi TT, Badlands
Looks awesome - consider the brake calipers in orange - subtle but might also look cool.
MaverickMan
Shane
SO when is the turbo upgrade, intercooler, exhaust, and tune getting installed. Ya know because its a Mach 1? Unless of course you are going for this stock 2.8 V6 styled beast.
Ford Bronco Mach 1 Bronco is done! c7R8-FAHaEh?w=317&h=194&c=7&r=0&o=5&dpr=1.65&pid=1
Ford Bronco Mach 1 Bronco is done! 1974-ford-mustang-ii-mach-i-photo-560825-s-986x603
martyb
martyb
Marty
Winneconne, WI
GMC Sierra Denali, VW Atlas
Any lift to fit the 315/70R17? Obviously you have to remove the crash bars, but any rubbing? This is the first 315 install I have seen with the Optional Badlands wheels and there is a few people that need to know what it takes to get it to work.
no lift or level on the stock Badlands suspension. I did pull the crash bars. The tire just barely touches the upper control arm at full left.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Honestly… I expected to hate it.
BUT, pleasantly surprised. Looks great!
Deleted member 12876
Guest
Nice!!
I’m going to accept my two door Badlands in orange as well.
martyb
martyb
Marty
Winneconne, WI
What were your thoughts on the Trail Armor rocker covers. I was thinking about getting those for my Cactus Gray Wiltrack (still at Dirt Mountain). I have the OEM side steps so I'm unsure of if it will look better or not. They are pretty expensive pieces of plastic.
they fit nicely behind the RB20’s, but I had to notch out for the brackets on the pinch weld. if you don’t have running boards they would probably look nice, but with the boards it was too much black and looked awkward. The factory running boards sit lower than the RB20’s so it might be OK. They won’t hold water in the seam, which a lot of people are worried about.
2PT7
Alan
San Antonio, Tx
what finish are the running boards? Textured black?
martyb
martyb
Marty
Winneconne, WI
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Your rig looks great! I have the Badlands with the option wheels and KO2’s. Has the bigger tire affected the ride and handling in anyway? Is there any poke with the standard flares? What engine/trans do you have?
Chaos_273
GMC Sierra
You may have already addressed this and I missed it, but did you have to remove the factory rock rails?
i really like how those RB20s look, and my wife would appreciate a step, haha.
martyb
martyb
Marty
Winneconne, WI
the tread lines up almost perfectly with the flare. I can see sidewall and the shoulder blocks, but not the tread. Ride is about the same, maybe a little more sensitive to grooves in the road. I have the 2.7
Ford Bronco Mach 1 Bronco is done! 621BA915-169D-41C1-B111-1EC13C97D583
