Mabett Mud Flaps 30% OFF NOW through 8/31!!
yokayyb
Marc
Vancouver
Bmw 340i, Kawasaki zx6r
man, is it possible to get just one? the driver side rear got ripped off on a rock lol.
FunForAll
WA
Bronco, 2 F-150s, Explorer, Mustang
Some install comments after installing the Mabett front flaps.
- I used stainless bolts and clips from Amazon.
- The bolts that go into clips on the fenders should be 20mm instead of 16mm long. A couple were hard to get started. It would be easier if they were longer
- Mabett should provide a new longer push pin for the in-board hole or maybe a screw. It is very hard to get engagement when you add the flap thickness.
Clip and bolt info:
https://www.amazon.com/dp/B0B529J9H4?psc=1&ref=ppx_yo2ov_dt_b_product_details
https://www.amazon.com/dp/B07PT62TCS?psc=1&ref=ppx_yo2ov_dt_b_product_details
Thanks for the recommendation and links.
Are you suggesting we go with the 20mm screws instead? Like these: https://www.amazon.com/dp/B07PN256NG?ref=ppx_yo2ov_dt_b_product_details&th=1
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
:eek:
Made an extension for the Mabett flaps. Now protects a little farther back. The BD General tires are also rock throwers.
How did you make them?
MNBronc
Lutsen MN
2022 Bronco
MNBronc
Lutsen MN
2022 Bronco
Kedward
Ken
2021 Bronco OBX, 2022 BB Sasquatch 7-speed
30% Discount Code: https://www.amazon.com/gp/mpc/A1PUIMJ7EJ76LB
Note: Please use a computer to open this URL
If you have successfully installed Mud Flaps, you can participate in this giveaway!
PRODUCT DESCRIPTION
  • 【Custom Molded】Fit full-size BRONCO, Fit All trim levels, Fit Sasquatch set, Accommodates factory rock rails or tube steps (If you have 35"s aftermarket wheels and no lift they will rub in some cases)​
  • 【Protect Your Vehicle】Protect fender and rocker panel from stone chips, slush, dirt and debris.
  • 【Prevent Accidental Sputtering】Protect your ride and those around you from the rage of the road.
  • 【Durable Material】Durable, impact resistant all-weather thermoplastic material
  • 【Buy with Confidence】It's free to return items if for any other reason you are not happy with your decision to purchase mabett mud flaps
I would recommend watching the installation video, as the instructions contained in it have some problems
will the 30% off work if you order only the fronts? I tried to order on Amazon but didn't work. Thank you
rdg698
Gil
South Carolina
Ford F-150
Ordered last night. I’ll go to Ace when they arrive and replace all the hardware with stainless…
BreezyNVegas
Rob
North Las Vegas
$152 Shipped! Should be here Tuesday.
Lakelife36
Ben
Interior of BC
@ProdigyJKU, @SoxFan, @MNBronc after installing these, what is your gut feel on removing each winter and reinstalling each spring? I'm considering going for a flare delete with winter pizza cutters, then back to the factory flares and mud flaps with much wider summers tires.
Rspayde
North Ga
2022 C/O Black Diamond
I am seeing a total price of $120 going to just buy these now and whenever mine comes in figure out the rest. Hope they fit!
Shredtron
West Palm Beach, FL
K2s
Bump:
Will the 30% off work if you order only the fronts? I tried to order on Amazon but didn't work. Thank you
rgroadking
Robert
Woodstock, GA
stuff
PRODUCT DESCRIPTION
rgroadking
Robert
Woodstock, GA
stuff
I don't see a discount code. I searched for the same thing directly from Amazon and it was the same price with or without the link provided!
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
I did the same thing--$199.99 either way.
Also: have you replaced the cheaper nuts, bolts, & fittings in existing mudflap packaging? Or are you going to ship existing (non-stainless) mudflap kits, exhaust that inventory, and THEN replace them with stainless?
If I order them (from Amazon), how do I know whether I have older (inferior) fittings or newer (stainless) ones?
MNBronc
Lutsen MN
2022 Bronco
When I did it, the discount did not show up until you checkout. The last screen before you submit order. It doesn't show in the cart.
