- First Name
- Josh
- Joined
- Feb 29, 2016
- Threads
- 54
- Messages
- 1,605
- Reaction score
- 3,561
- Location
- Tenneessee
- Vehicle(s)
- 2013 Raptor, 1973 Bronco
- Your Bronco Model
- Wildtrak
So adding lights would completely block the site on the camera.
Comparing the photos, I seriously doubt it.
Pretty sure you cannot attach it to the plastic bumper.Apologies if this is obvious, but does this fit on all of the bumper options, or is it specific to the modular one for example. Thanks!
If you didn't use the brackets that came with the lightbar and welded on some tabs to the tube it looks like it would definitely work/fit.
Awesome! Just made the order!Greta quality and very easy to install. Only blocks the camera a little on the bottom portion of it:
Pretty sure these or torx plus. not regular torx. if you are using regular torx... then you will strip the bolts. I'll check in a bit but every other bolt of removed/reinstalled on the mod bumper so far are all torx plus.If you have issues getting the bolts off, I would recommend trying a T35 instead of a T30 torx. For some reason some of my bolts were already a little stripped even though I have never taken them off before installing this bar. The T35 definitely helped getting the stripped ones off and made life a lot easier.
Yes, you're right. Torx plus for sure.Pretty sure these or torx plus. not regular torx. if you are using regular torx... then you will strip the bolts. I'll check in a bit but every other bolt of removed/reinstalled on the mod bumper so far are all torx plus.
specific to the modular one for exampleApologies if this is obvious, but does this fit on all of the bumper options, or is it specific to the modular one for example. Thanks!
Not fit capable bumperI was also wondering if it fits the capable bumper.
They only stated that it would not work with the plastic bumper:
This kit is not compatible with models that use a plastic bumper.
ThanksNot fit capable bumper
