Mabett front mud flaps installed
Summertime
Roger
Kansas City
2022 Bronco Outer Banks
I put mine on a few days ago. I like the way the fit. Hopefully less rock chips.
Is this a non-Sasquatch installation? I have a 2022 OBX. Tires are 38x20x12.5, but non-sasquatch.
MikeyC
Starks, ME
2005 Toyota 4Runner
Mine in non Sasquatch with 32 inch tires. The flaps fit the Sasquatch too. Not sure about 38’s though.
Summertime
Roger
Kansas City
Oops. 35", not 38".
You installed front and rear, correct?
MikeyC
Starks, ME
2005 Toyota 4Runner
Oops. 35", not 38".
Yup. Front and rear. It should fit aftermarket 35’s. I know it fits the Sasquatch.
Summertime
Roger
Kansas City
No trouble getting the rear flaps to fit? Seems like others on this string have had problems.
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
Do you have a photo that shows the flaps with non-sas fender flares from behind/rear quarter?
Wildfire1
Paul
Nfld, Canada
1993 GMC 4X4 / 2012 Mustang convert
Here’s a close up picture
The nut is supposed to be on the inside of the flap. When I did mine I ended up putting all stainless steel hardware on them because the nuts and bolts started to rust.
Ford Bronco Mabett front mud flaps installed B10D8212-11D2-4F11-B46D-75E8991CE066
MikeyC
Starks, ME
2005 Toyota 4Runner
I switched to the stainless too. I just liked the look of the Allen heads in the wheel well better.
Ford Bronco Mabett front mud flaps installed CFDF9A12-3109-44D0-8A40-B25A2DD76E83
Wildfire1
Paul
Nfld, Canada
Cool. I went with all stainless, nuts, washers…anyone that does this keep in mind the front hardware is smaller than the rear. They are great mudflaps. They look like they came with the Truck.
MikeyC
Starks, ME
2005 Toyota 4Runner
Yup. I did the front with stainless too. I actually got rid off the plastic factory fastener and used a stainless Allen there too.
Ford Bronco Mabett front mud flaps installed E1FD5E9A-47B5-4D17-95D1-93A0EADEC8DC
KCHorse
KCHorse
Kansas CIty
2018 Jeep Wrangler- Sahara
I installed the fronts on my Badlands | SAS with 1.25" BORA spacers installed. I got a little rubbing when backing out of a driveway and turning. The tire was catching the part that juts in and around the crash bar that is not there. So, I removed them and sliced off half the thickness of that gusset, only where it juts in and out. No more rubbing and I am 100% satisfied with the way these look.
Do you have a pick of the portion you had to slice off? I would rather preemptively slice it off.
THANKS!
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
There is NO cutting or modifying with this setup. It's all BOLT-ON. I love mine. I recently went hardcore off-roading, rock crawling as well and the flaps held up fine. And they look so OEM :)
Ford Bronco Mabett front mud flaps installed 52333695852_ecbafbd5f5_b
