Mabett Fog Lights Not Working
waystinthyme
Jonathan
Chicago
21 Bronco Badlands
I ran the fog lights to two 10 amp aux switches (3 and 4), grounded at the negative terminal, checked both 10 amp fuses, reattached all harnesses, and it's still not powering on. Any ideas?
Headsong
I don't know how yours work, but when I replaced mine I remember that they're polarized so you may want to just flip the connection.
waystinthyme
waystinthyme
Jonathan
Chicago
21 Bronco Badlands
Thanks! When you say 'flip the connection' are you referring to the various harnesses or one specific place?
CUPRA
Jared
'21 Bronco OBXSAS/'23 Camaro SS Convertible
Which fog lights are they and did they come with a remote?
I’ve tested several sets of Mabett fog lights, from the Raptor style, to the 4 and 5 bulb versions too. A couple of them came with a remote with them.
Headsong
I seem to remember it was the connection to the light assembly.
waystinthyme
waystinthyme
Jonathan
Chicago
21 Bronco Badlands
thanks for the input guys. I ordered the raptor style with no remote with the intent of using the aux 3 and 4 positions. I've watched 3 youtube tutorials, reran the wires, tried using my own twist connectors, moved the ground wire location, and checked the engine's aux fuses, and the mabett fuses. Unfortunately still not working so i ordered an exchange.
Eroc88
Ohio
Jeep
I would check and make sure that all the pins in the male connectors are all aligned with the female connectors. I have these fog lights when installing, my driver side wasn't working come to find out one of the pins in the connector needed adjustment.
