Lux package not worth it at all
joshofthefall
Josh
Illinois
2006 Scion tC
I would personally be THRILLED if that price jump included leather.
Otherwise I hope the B/O system is a stand alone option as well.
I'll join you in that sentiment. I'm okay with the (reduced... OBX ?) cost just for the wheel + ACC + sound system, so if leather is included as well that'll just be the icing on the cake.
jaruss01
NJ
I think they confirmed during Q&A that B&O is not standalone, unlike other Ford models.
Personally, I'll HAPPILY pay $2,300 just for ACC and B&O (both of which are a near-must). I'm just glad they didnt tack on a lot of other stuff i dont need/want and i had to pay even more to get ACC/B&O...My wife just hit me up on custom window treatments, that frankly, i could care less about. The lux package is the equivalent of just 2 windows...so yeah, do i care more about the lux package than 2 sets of curtains? You bet.
lowmpg
Ryan
Maryland
F350
You should be able to swap the steering wheel for the version with heat and then code it with FORSCAN. It works on the F150 platform.
Not remotely that simple. I looked in to doing it on my F350, way more complex than 'swap a wheel and run ForScan', and far more expensive. Not worth it at all.
Silver-Bolt
Bill
Eureka, MT
Interesting. The Raptor guys are swapping out the wheels and coding. Boom, heated wheel. Can't speak for the Super Duty's. Cost is ridiculous for that single feature.
Deleted member 13955
Guest
For me ... ACC is the ONE thing I would leave OUT of the Lux package if I could.
First experience I ever had with ACC was in my 2010 Jag XFR.
Didn't like it then and still don't like it.
I'm curious to see what Sync4 will be like. The voice activated Nav (Sync3) in the F150 Limited is pretty nice overall. I like it better than Google/Apple maps and other Nav systems I've used.
The B&O is good (not great) but I've found in life that:
"Always better to have something and not need it than to need something and not have it" (lol).
$2300 used to be the entry point JUST for Nav, so it's not an outrageous cost in my opinion for the Lux package.
Headsong
Gloves solve the problem. I still think they'll have a Cold Weather package. They're from DETROIT!!
lowmpg
Ryan
Maryland
F350
Maybe, but I'm willing to pay :)
lowmpg
Ryan
Maryland
F350
I can guarantee it isn't easy. Nor is heated seats, not if you want them anywhere like factory. Well worth the money to have it done. Below is the parts list to add a heating steering wheel to a Raptor that didn't come with one:
Parts List: Heated Steering Wheel (2013-2016) - Pick one: ES7Z-3600-UC - Fusion without Paddle Shifters (based on part description, haven't seen non-paddle one in person to confirm) ES7Z-3600-VC - Fusion equipped with Paddle Shifters Heated Steering Wheel Clockspring: EG9Z-14A664-A Heated Steering Wheel Module: DG9Z-14B561-A Heated Steering Wheel Module Mounting Bracket: DG9Z-19A435-A Heated Steering Wheel Mounting Bracket Nuts: N621901-S424 - Need 3 (Individual) or one (Package) of 5 Heated Steering Wheel Mounting Bracket Bolts: W505423-S439 - Need 2 (Individual) or one (Package) of 4 Heated Steering Wheel Module Wiring Pigtail for C2406: 3U2Z-14S411-BJAC (WPT-955) Clockspring Wiring Pigtail for C2414C: 3U2Z-14S411-AEB (WPT-965) Clockspring Wiring Terminal Insert for C218A: DU2Z-14474-BA (WT-1001) - Need 2 (Individual) or one (Package) of 5 BCM Wiring Terminal Insert for C2280H: EU2Z-14474-AA (WT-1009) - Need 1 (Individual) or one (Package) of 5 - Only needed if vehicle is FWD, as AWD will already have this wire present. (OPTIONAL) OBD Test Connector Wiring Pigtail for HSWM CAN Bus (Instead of splicing Existing GPSM Wiring): 3U2Z-14S411-LUB (WPT-977)
Silver-Bolt
Bill
Eureka, MT
Go check out the FRF forum. It has been done many times. Over on F150 they are adding the Raptor wheel to non-Raptor 150's and getting the paddle shift to function as well. From the factory is by far the least expensive no question.
lowmpg
Ryan
Maryland
F350
You're totally discounting the time invested and knowing what you're doing. I've taken apart F series dashes, not a chance when I can spend a few grand (10/mth) and wrap it and more into a new car. IMO clearly not worth it. Who spends this much money then rips into the dash...not me :)
Jotica
Milwaukee
Subaru XV
Part of the reason I want a Bronco is for more cargo space for gear... anyone has any idea how much cargo space does the subwoofer takes up?!?
I like the Lux package, but if that subwoofer takes a bunch of cargo space it will only be High package for me.
Bronc-O
Phoenix
2021 Lincoln Aviator
The sub fits into the passenger side panel and is flush. No extra room is required.
