Lost audio front passenger side
brainzito
Miami
Bronco Outerbanks
Installed new speakers yesterday dash and kick panel. All worked ok, today it all sounded kinda flat, when checking I lost all audio on the right front side.
just rechecked all connections and nothing was loose. Even tried the oem speakers, nada.
Any tips?
brainzito
Miami
Bronco Outerbanks
HELP
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
did you check the simple stuff - left/right fade? reset the head unit?
brainzito
Miami
Bronco Outerbanks
I did…nothing!
TheKim
Kim
I guess put the OEM speaker back in and take it to the dealer for warranty work. Could be wiring, could be the head unit. Let them figure it out and replace/fix what ever is broken.
SoCalG
SoCalG
Southern CA
2022 2DR Bronco BD
have you lost audio for all inputs or a specific input. This happens to me sometimes while using Spotify via apple carplay. all other audio inputs seem to work fine. When I kill the Spotify app on my phone, it starts working again.
If this is not it, time to pull apart the side that is having an issue and test or re-crimp your connections..
BBBronco
Johnny
ATX
2021 Bronco Sport
Tried to find a thread related to my issue, I’ll post it here.
I replaced dash and roll bar speakers with 4” kickers. Swapped speaker wires for dash/ roll bar, so if I fade full front I have kick panel and roll bar speakers. Full rear is now dash only. All good. Until I replaced the kick panel speakers. By removing the factory kicks and the 4 pin connectors, now I have no roll bar speakers. Where do I go from here? Thanks
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Trying to figure out how you did that you would of had to run additional wires to either the kick panel speakers or the dash speakers, the dash speakers and kick panel speakers are wired in parallel
Ford Bronco Lost audio front passenger side 1658881576991
BBBronco
Johnny
ATX
2021 Bronco Sport
Yes, the wires for both roll bar speakers run on drivers door sill. For drivers side I just directly swapped dash and roll bar wires. For passenger side I had to run jumper wires to and from passenger kick panel speaker. Everything worked fine until I replaced the 6.5” speakers. How is that 4 pin connector wired, I guess that’s my question
