Loose Rigid fog lights?
Monte87
Anthony
2022 Bronco
Hey Fellow Braptor guys & Gals,
My Rigid fog lights are loose, is this common on Bronco Raptors?? or just normal.. I had a 2023 F150 w same lights and never had an issue. Just wondering... How can i tighten them up, adjust etc?? Or if they get loose they are DONE & need replacement? Please let me know, Thank you in advance!!
Cheers, Anthony
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
... well if you are moving the light from the outside... there are a lot of moving parts and nuts/bolts.
May need to provide a little more of what's going on? Believe it's just a couple of fasteners to remove the back cover.
Ford Bronco Loose Rigid fog lights? Screenshot 2026-05-05 at 2.33.33 PM
Ford Bronco Loose Rigid fog lights? Screenshot 2026-05-05 at 2.33.00 PM
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Those fasteners to remove the rear cover over the fogs is a major PITA. There's probably a specific tool to remove them easily. I think I used angled needle nose pliers (big ones) to get them all out and I still ended up destroying one. But yeah, once apart, the lights are held on by a few small screws. Easy enough to tighten.
You're the first I've seen mention the issue so might just be a built on Friday thing.
Monte87
Monte87
Anthony
2022 Bronco
Hey Q1 - Thanks for the reply and illustration. Greatly appreciate the visual... I was just wondering if there was just like 2 set screws for tightening LMAOOOO cant be that simple. Anyhow, appreciate you!
Anthony
Monte87
Monte87
Anthony
2022 Bronco
Hi Ape-
TY 4 reply!!! I have those same exact angled needle nose pliers lol Thanks for heads up! I will try over weekend. I also have tons of tiebacks in case they break. I will keep ya guys posted!!!
Cheers, Anthony
Q1svt
Sunny & Warm SoCal
@Monte87 no clue... but it's four push pins that hold cover. I had the pictures, like many thought the lights looked good... then heard they are not that powerful, and stopped [non-raptor owner] Thinking about it, if they were easy to take off there would be more on theftBay....
Here's a video I had saved...
