Looking for alternative to "Fuse Tap"
Loeb
Loeb
Tacoma
'25 Badlands
When tapping into the spare fuse positions in the fuse blocks, there is only one type of device I have been able to find, the micro2 fuse tap. It has 2 fuses because it is intended to preserve a preexisting circuit, not a concern when using a spare fuse position. It is also right-angle, so it sometimes doesn't fit the position you want to use.
Ford Bronco Looking for alternative to "Fuse Tap" 1786251025888-9g
Does anyone know of a micro2 fuse tap that is a straight tap and has only one fuse, probably inline on one of the leads?
I know that fuseboxes don't have lines coming off each fuse, and this advise isn't always practical, but...
I think in most cases like this, folks would just hit the line coming out of that fuse, or... pick a fuse in a different position to make it fit.
Roger123
Roger
VA Beach, VA
Cut the end off of this and make your own.
Fuse Tap
