Looking for 2021 or 2023 APIM and HVAC as built values!
a_Panda
Rochester, NY
2022 Bronco, 2020 XC60, 1978 124 Spider
Hey all,
I have a 2022 Badlands Mid Pack. I did a retrofit to add the 2021 hvac module and get the temp display dials. I am looking for someone to share APIM and HVAC as built values from a 2021 (or maybe 2023) so I can see what values may disable the screen overlay temperatures on the 8 inch display. Similarly, if anyone has any ideas, let me know...
I tried disabling "temperature repeater", "climate dual overlay", and "climate overlay mode". None of these resulted in removing the overlay popup when changing temp or the temp displaying at the top of the screen.
Thanks in advance!
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I'd be interested to know if anyone that has the temp on the knobs from the factory does not have the temp on the screen - I would assume it is on the screen as well as the knobs from the factory.
a_Panda
a_Panda
Rochester, NY
This is a good question, ha. I guess I just assumed Ford wouldn't default it to two places... 😅
cbrenthus
Western PA
Like the side by side speedometers? :ROFLMAO:
And I was disappointed about the temp on the knobs, but now I'm actually happy I don't have them as the interior is less "busy" ;)
a_Panda
a_Panda
Rochester, NY
Anyone care to share 21 mid pack as built values? Anyone at all?
...Bueller...
...Bueller...
spartacus1882
Sean
Dallas
2022 Bronco
...Bueller...
...Bueller...
Did you ever find the information you were looking for? I am thinking about tackling this soon. I don't like the temp on the display. Makes it too busy.
a_Panda
a_Panda
Rochester, NY
I didn't.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
I have a 23 with temp knobs. I have not played with forscan yet but assume the APIM and HVAC as built values are thru that. I just received my OBD2 yesterday and I can try looking tonight. Unless you happen to know which address to check in the as built modules
a_Panda
a_Panda
Rochester, NY
That would be awesome! I don't know the address yet and haven't seen anything that worked in the plain text mode. If you want to pm me your as built values, I can search for differences between the two. Happy to share mine as well. As built can be downloaded from here without even plugging in...
https://www.motorcraftservice.com/Home/SetCountry?returnUrl=/AsBuilt
huey
kevin
Ontario & Kentucky
I already have my as builts - will pm now
spartacus1882
Sean
Dallas
2022 Bronco
Any update on removing the temp from 12" screen?
a_Panda
a_Panda
Rochester, NY
I got it off the 8 inch. Not sure exactly what combo got it off though. In apim, I changed status bar temp (on 7d0-02), turned off temp repeater, turned off fan repeater, went into hvac and changed it to centerstack. Back in apim I enabled climate domain then disabled it again and I think that dual write maybe got the values to finally take. Sometimes the modules can be a bit finicky in my experience.
