Limited Manual Options?!
TXRancher
Brownwood TX
2011 F150
It most certainly stinks.
RupertH
RupertH
Rupert
West
Mostly
That is correct.
Not only limited engines, limited packages.
And in a year, Ford will put out a release dropping the manual citing low take rate. "We offered it, and no one wanted a stripped down POS just to get a proper transmission."
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
What did your build consist of? Final numbers?
Considering manual, but probably going auto. A built 2.3 manual might be interesting though.
It's been ages, but here's the thread
I got the JDM Dyno at my parents house, think it was 275whp, but on Truck rollers, when on a normal dyno was 311whp but with a few less parts installed
RupertH
RupertH
Rupert
West
Mostly
Wow, and the admin changed my title- Suck it FORD!!!!!!
Chrome_Pony
Chrome
The Great Land
captchathis
Tacoma
Wow my enthusiasm for the bronco went from 100-0 real quick after reading the spec sheet showing only manual for 2.3.
I would settle for an automatic only if it was a V8 and that is still a rather large compromise on my end.
Monster79
E
Alabama
15'Stang, 07'F150, 23',96',93',79'Bronco
Eh I guess I'm glad I will be getting the auto.
Rogues Gambit
Eatontown, NJ
Rogues Gambit
Eatontown, NJ
Miss her, it's a long story but she was a good girl, even if she was an automatic.
Time slips were from when she was stock, 19 was what happens when you turn off both traction's, smoke the tires and nearly crash into a wall xD
Let my sister drive her as you can see btw
Ford Bronco Limited Manual Options?! 20151224_191621
Ford Bronco Limited Manual Options?! 20151225_003610
Ford Bronco Limited Manual Options?! IMG_20150923_214059795
Ford Bronco Limited Manual Options?! IMG_20150923_214230647
Ford Bronco Limited Manual Options?! IMG_20150923_234526669
Ford Bronco Limited Manual Options?! IMG_20150923_234650151 (1)
Ford Bronco Limited Manual Options?! IMG_20150923_234655509
Ford Bronco Limited Manual Options?! IMG_20150923_234702336
Ford Bronco Limited Manual Options?! IMG_20150928_161439223
Ford Bronco Limited Manual Options?! IMG_20170202_114352
Ford Bronco Limited Manual Options?! IMG_20170202_114424
Ford Bronco Limited Manual Options?! IMG_20170228_153808
Ford Bronco Limited Manual Options?! IMG_20170312_192912
Ford Bronco Limited Manual Options?! IMG_20170518_131259
Ford Bronco Limited Manual Options?! IMG_20170825_161606
Ford Bronco Limited Manual Options?! IMG_20170926_173455
Ford Bronco Limited Manual Options?! Shelby
TeocaliMG
Plymouth Michigan
I'm honestly surprised that people are surprised by this, sometimes I forget what is common knowledge and what is insider knowledge. I have known for quite some time that my heart would be torn between the manual/2.3 and the 2.7 BAJA style. And just when I convince myself to get the manual and throw on the suspension package, that 2.7 starts whistling in my ear... This is going to be hard!
TeocaliMG
Plymouth Michigan
If getting basically every bit of equipment EXCEPT the 2.7 counts as stripped down then I think you should ask your local strip club for a refund...
https://www.ford.com/cmslibs/conten..._lineup_HR.pdf#badlands|wildtrak|firstedition
Cough, badlands, cough, tune...
MaverickMan
Shane
I know the 4dr we get will be an auto. but damnit I want the stick. And the big motor because, well because I f'ing do.
Im hoping this gets sorted by the 2nd year. Lets all outrage a bit so they will make it happen.
The Pope
With the 2-Door being a HALO Vehicle, the manual should have been available with both engines on the 2-Door at least.
FoMoCo..... Way to Tarnish the HALO...... , but you do still have a chance to rethink this (and a few other things) and hopefully correct (in enthusiast's minds) this before 2021.
