Limb Risers... Availability? DIY?
BaseSquatch
@NotOJsBronco
A lot of the preproduction Broncos had really cool looking “limb risers” attached. I’m sure they’re equally as helpful on trails with a lot of overhanging brush.
I don’t see them in the Ford Accessories catalog. The only place I’ve seen them is
here, and they’re sold out. Anyone know where else they’re available? Or if they’d be easy to make on my own? I’d like to use the existing mounting points, rather than drilling into the sights/panels.
Limb Risers Pictured Below
Ford Bronco Limb Risers... Availability? DIY? 0ECB2994-155F-4FF4-8E0A-9A86BD6360BE
BroncoKong Jr.
Andrew
Ford has no plans to make them. And the one listed on that site is for a Maruti Gypsy.
BaseSquatch
BaseSquatch
@NotOJsBronco
Ford Bronco Limb Risers... Availability? DIY? E3DFC333-6193-41F0-A49E-B63EDEB40FCA
A Maruti Gypsy huh? Hmm... You think they’re compatible? If so, maybe I’ll just look for Gypsy limb risers.
BaseSquatch
BaseSquatch
@NotOJsBronco
BroncoKong Jr.
Andrew
So you think Bronco Bastards is just ripping people off with non-compatible Gypsy accessories? Got it. Thanks for the heads up! Saved me some money.
They don't actually have any product from what I can tell. They just google image search stuff and list it. Most of their listings are for Jeep stuff.
Check out this sweet Ford Bronco Grill
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '05 F-350; '07 Camry
Wait for it - they will come. Most accessory makers don't even have access to a real Bronco yet.
A year or two from now we will be flooded with all kinds of add-ons, from good and useful to tacky garbage - whatever suits your fancy.
BaseSquatch
BaseSquatch
@NotOJsBronco
I know you’re 100% right... But I’m not patient enough to wait 2 years for limb risers 😂
I’ll probably find a way to make my own somehow. It shouldn’t be too hard since the trail-sights are already there.
Gangstead
'21 BD 4DR 7MT Soft
The garbage will do!
BaseSquatch
BaseSquatch
@NotOJsBronco
The actual cable isn’t the problem.😂
Mounting it so it’s sturdy, and doesn’t look trashy is the hard part. I don’t want to necessarily drill into the trail sights or panels. I’m hoping to take advantage of the existing mounting points.
Ford Bronco Limb Risers... Availability? DIY? 72BD16B2-2537-4818-AE94-0FAEEADFE985
BaseSquatch
BaseSquatch
@NotOJsBronco
@4 Wheel Parts, Can you make some Limb Risers for the Bronco? We need something that takes advantage of the stock trail sights.
I purchased the side-steps you made for the Bronco, and they’re fantastic. I know you cold come up with a great limb riser solution.
