Light Bar Inside Grill Opening
Brad Fx
U.S.A
Jeep Commander
Anyone have a light bar installed inside the bottom grill opening? Will this work, any sensors, etc there? Light bar recommendations?
Ford Bronco Light Bar Inside Grill Opening 6B3EFA3B-D80C-44C5-909F-06A1F9AB6B8E
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
It would have to be a really small light bar! It won't be long before aftermarket grilles with light bars start showing up.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Initially that’s what i wanted to do just to make it look clean. That’s what i did to my Tundra (behind the grille). For the Bronco i don’t think it’s possible, not enough room so I ended up having someone make me a small bull bar with tabs for the light bar. I just went with a 20” single row.
Ford Bronco Light Bar Inside Grill Opening 202D8541-6900-4125-96AD-BFA09379D9BB
Ford Bronco Light Bar Inside Grill Opening 3DBAA0A1-06EE-478B-9FFA-3DA346D02F80
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Not enough room. Almost all of the light would get blocked
privateer35
Seattle
Ford Bronco 2021
One day scrolling on Instagram I saw this on someones bronco. I'm kicking myself for not saving the post nor screenshotting it because I like the stealth look.
What I will say, after digging up some installation diagrams, it's a moderate risk to engine cooling. Take it with a grain of salt since I'm not a car expert, but nor do I think the lightbar would completely block the opening and would still allow air in.
Ford Bronco Light Bar Inside Grill Opening IMG_9467
Brad Fx
Brad Fx
U.S.A
Jeep Commander
Thank you for this graphic. This is really important info. That’s why I ask these questions. It seems like even adding a bar to the bumper technically might block the airflow as well, but hopefully not as much.
MandRautomotive
Mikhail
CA
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
So my friend got this light bar and it honestly fits perfect in that spot. It literally slides in that area and is held in there on it's own and really tight snug fit.
For some reason pics aren't uploading but this is the light bar. I can DM you if you want pics or try it again later. I know this an old post but just came across it.
https://www.amazon.com/dp/B0CWXL67W4/ref=twister_B0D1BNXZPJ?th=1
