Leaking water at tailgate
CoopDawg
Coop
Springfield, GA
2021 Ram 1500 Longhorn, 2022 Ford Bronco OBX 2 dr
This is my daughter's Bronco. She loves this thing.
Ford Bronco Leaking water at tailgate 1000004085
Problem we are having is there is a gap that water is seeping in. Below are the best pictures I could take. I can definitely layer some automotive grade gaskets, but I'm hoping there is something out there made for this issue. Any ideas?
Ford Bronco Leaking water at tailgate 1000005127
Ford Bronco Leaking water at tailgate 1000005121
stevenstommyboy1
Thomas
Menasha Wisconsin
2023 Bronco Raptor
Would have to look at the parts breakdown for that area. See if there is one there. I can look at mine after work also.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Ford Bronco {thread} {filename}
Wanted to compliment your daughter on her Bronco. Looks great in all black. The gap is present on all Broncos. But the OEM HT has a "lip" gasket on the glass that seals against the tailgate. Her Bronco has an Armadillo HT. You might want to reach out to them to see if they have an "official" part. Otherwise you'll be left concocting your own seal.
CoopDawg
CoopDawg
Coop
Springfield, GA
Yes, that is the "lip" gasket that I refer to on the OEM HT. The Armadillo HT that the OP's daughter has doesn't have that.
Anyone have the part number to order?
I have a Rallytop and the gap isn't that big, but it still leaks
I just layered some small pieces of weather stripping there. The leak isn't 100% stopped, but it went from big puddle in the back to a few drips when it rains.
