Leak ... not sure what it is
Atoledo95
Alan
Los Angeles, CA
2022 Ford Bronco Outerbanks
Hey Everyone,
Unfortunately, I have a leak and not sure what it is 🤦‍♂️. Thinking either trans, steering fluid, or the main one which I believe it to be is the cv leaking. Just bought the 74 weld steering so that’ll be fine. Realized some of it yesterday and today saw way more leaking. Still drivable and crazy sounds. Getting checked out Monday and ordering whatever it is replacements for it. Thinking Dana shafts or rcv shafts, if this is the issue. It’s the driver side leaking to. Would like ppls suggestions or thoughts on what it could be. Thanks 🙏
Ford Bronco Leak ... not sure what it is IMG_8484
Ford Bronco Leak ... not sure what it is IMG_8486
Ford Bronco Leak ... not sure what it is IMG_8480
Ford Bronco Leak ... not sure what it is IMG_8482
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Looks like cv shaft grease to me.
Agree, highly likely. See how it looks like the grease is being flung around by rotating shaft? I would do a very close inspection of the rubber boot on that side and I bet you find a split somewhere.
Haustkraft
Holden, MA
1994 Bronco
How long have you been driving it like this ? Time for a next axle !
V1Rotate
Brevard, NC
2022 Wildtrak
Definitely in the area a CV boot will throw grease if it has a hole. A little grease will make a lot of mess.. that’s not much grease IMO and you’ve got a while before it’s dry. I chased a pin hole for a month or so then finally just replaced the axle. Once I had it off and all apart I cleaned it up and used some gear-aid Aquaseal FD and sealed the boot and shot full of grease.. now I have a spare driver’s side axle
Atoledo95
Atoledo95
Alan
Los Angeles, CA
I’m going tomorrow to get it analyzed but bought some rcv axle shafts in case
