Largest tire without recalibrating speedometer?
Bob 07064
Bob
Somewhere in time and space
02 4x4 ranger, '17 edge 2022 Bronco
What's the largest tire I can put on my two door without recalibration of the speedo?
Doc Brown
Delaware
2012 Kia Forte
What trim? Sasquatch?
Bob 07064
Bob 07064
Bob
Base, so I can really make it my own
Gamecock
Bob 07064
Bob 07064
Bob
Erock
US
2018 F150 Alpine edition
At highway speeds, 1” difference in tire height changes the speed around 2 1/2 mph or so. Crude numbers... but it was what I used on older vehicles instead of changing the speedometer gear
Monster1926
GMC Sierra 2500HD
I’d say 33s. After that you’re going to want to get the speedo recalibrated and I think your transmission shift points will be different to with larger tires.
kodiakisland
Arkansas
I’ve never recalibrated the speedo and always run bigger tires. I can add 2-3 in my head most days. My initial tire swap will be off by 4%, so I’ll just remember when the speedo says 100 it’s really 104.
Wonder how dead on accurate the speedo is in the first place?
kodiakisland
Arkansas
Shift points should be based on rpm, not mph.
kodiakisland
Arkansas
Sport mode should shift at higher rpms and that should help with the bigger tires, both in increased weight and reduced gearing. I prefer to row my own, so I don’t have to worry about that.
Monster1926
GMC Sierra 2500HD
I don’t have sport mode. If I get a bigger tires I’ll just re-calibrate. Tune and possibly bigger turbos are the plan.
kodiakisland
Arkansas
Don’t forget the gears. That’s my biggest concern when going to bigger tires. Correct gears cure a lot of ills bigger tires bring.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
You don’t ever have to recalibrate for bigger tires. It’s just so your speedometer reads correctly. It’s usually a trivial matter to do with the right tool, but I wouldn’t worry about it too much if you don’t have the ability at first.
As pointed out, depending on the delta between tire sizes, regearing can have a huge and vital impact.
(Not always necessary, but at a certain point, I feel it’s worth the expense.)
Quinn_the_eskimo
Cave Creek, AZ
1981 Jeep Scrambler, 2021 Jeep Gladiator
Someone should have a way to tap into your OBD to change it, no? I can on my gladiator using a bypass connector and an app on my phone. The connector is like $35 and use of the app is another $20. Bluetooth OBD readers run anywhere from $20-100. That allows me to reprogram most anything a dealership can.
Most sites with tire size charts have details on gearing, too - with "sweet spots" highlighted. Go outside of that and you'd need to jump up in gearing or you're putting excess strain on your driveline and bound to tear up u joints and trannys.
