Keyless Entry Code - How to find it through Sync
LagoCJ
CJ
Lago Vista, TX
BRaptor and GMC Canyon AT4X
Weird one...
I have the Keyless pad on my Bronco. The code that is on the factory card works just fine, to open the doors. But, when I enter the same code into the Sync system to add a personal code or anything else, it tells me the code is incorrect.
So, I did the 'look on the Internet...the web knows all' thing and found these instructions, FROM FORD -->
https://www.ford.com/support/how-to...ess-entry-code-for-my-intelligent-access-key/
But...no code shows up in the dash display, or the center display, to tell me what Sync thinks my code is...
Anybody have any other ideas? Like I said, the door keypad works just fine, with the code from the factory plastic card. But, I can't use that code to make any changes as Sync doesn't recognize it.
Any help (Ford?) would be appreciated.
RagnarKon
Ford Bronco, Escape, Focus
I answered your question over on Bronco Nation, but just for the benefit of everyone on this forum...
The keypads that come with the full-sized Bronco are not the standard Securicode keypads that are built into the doors of most Ford vehicles. The pads on the full-sized Broncos are wireless RF keypads that are stuck on the door with double-sided tape. Since they are not the standard keypads, the programming steps are different.
Steps to add a personalized code:
  1. Enter the factory code on the card
  2. Within 5 seconds, press and hold the 1/2 button until the 9/0 button flashes twice. After it flashes twice, you have entered programming mode.
  3. Enter your desired personalized 5-digit code. The vehicle will go through a unlock-lock-unlock cycle.
  4. If programming is successful, the 9/0 button will flash twice to confirm.
Steps to remove the personalized code:
  1. Enter the factory code on the card.
  2. Within 5 seconds, press and hold the 1/2 button—continue holding the button. The vehicle will go through a lock/unlock cycle.
  3. The 9/0 button will flash four times to confirm the code has been removed. After you receive the confirmation, you may release the 1/2 button.
LagoCJ
LagoCJ
CJ
Lago Vista, TX
Saw the note over on BN as well. THANKS!! Great info and very helpful.
CodeOrange213
Mo
CT
BRAPTOR
Great info, however what if I don’t have the original factory code or the card?
Someone did some math and came up with a really really long number (3,125 digits) you can enter - since the Keypad doesn't reset after you enter 5 digits, you can just keep hitting numbers and once you get the right 5 digits it unlocks. In math circles, it's called a "de Bruijn sequence"
Granted, it could take like 10-15 minutes of mind-numbing entering of semi-random numbers while listening for the door to unlock.
Code:
 11111311115111171111911133111351113711139111531115511157111591117311175111771117911193111951119711199113131131511317113191133311335113371133911353113551135711359113731137511377113791139311395113971139911513115151151711519115331153511537115391155311555115571155911573115751157711579115931159511597115991171311715117171171911733117351173711739117531175511757117591177311775117771177911793117951179711799119131191511917119191193311935119371193911953119551195711959119731197511977119791199311995119971199913133131351313713139131531315513157131591317313175131771317913193131951319713199133151331713319133331333513337133391335313355133571335913373133751337713379133931339513397133991351513517135191353313535135371353913553135551355713559135731357513577135791359313595135971359913715137171371913733137351373713739137531375513757137591377313775137771377913793137951379713799139151391713919139331393513937139391395313955139571395913973139751397713979139931399513997139991515315155151571515915173151751517715179151931519515197151991531715319153331533515337153391535315355153571535915373153751537715379153931539515397153991551715519155331553515537155391555315555155571555915573155751557715579155931559515597155991571715719157331573515737157391575315755157571575915773157751577715779157931579515797157991591715919159331593515937159391595315955159571595915973159751597715979159931599515997159991717317175171771717917193171951719717199173191733317335173371733917353173551735717359173731737517377173791739317395173971739917519175331753517537175391755317555175571755917573175751757717579175931759517597175991771917733177351773717739177531775517757177591777317775177771777917793177951779717799179191793317935179371793917953179551795717959179731797517977179791799317995179971799919193191951919719199193331933519337193391935319355193571935919373193751937719379193931939519397193991953319535195371953919553195551955719559195731957519577195791959319595195971959919733197351973719739197531975519757197591977319775197771977919793197951979719799199331993519937199391995319955199571995919973199751997719979199931999519997199993333353333733339333553335733359333753337733379333953339733399335353353733539335553355733559335753357733579335953359733599337353373733739337553375733759337753377733779337953379733799339353393733939339553395733959339753397733979339953399733999353553535735359353753537735379353953539735399355373553935555355573555935575355773557935595355973559935737357393575535757357593577535777357793579535797357993593735939359553595735959359753597735979359953599735999373753737737379373953739737399375393755537557375593757537577375793759537597375993773937755377573775937775377773777937795377973779937939379553795737959379753797737979379953799737999393953939739399395553955739559395753957739579395953959739599397553975739759397753977739779397953979739799399553995739959399753997739979399953999739999555557555595557755579555975559955757557595577755779557975579955957559595597755979559975599957577575795759757599577595777757779577975779957959579775797957997579995959759599597775977959797597995997759979599975999977777977799779797799979799799999
