KC Lights on Capable Bumper
FatRat250
Easton PA
22 Bronco Badlands Squatch Lux Hot Pepper
Seems solid enough to me. I have not tried running down a really bumpy road at night, but no wobble from the bar when you grab and pull.
I can't comment on the camera since I don't have one. If it would help, I can take additional pictures or measure distances for you.
Thanks for the offer. I’m on the road right now I’m not near my bronco but I do have another question if you don’t mind. Where are the feet of the bar mount to the bumper, is there any contact with the painted bodywork that sits above the bumper and below the grill with the bar? I saw one picture from the side but I can’t tell how much clearance you have. I like the idea but want to make sure that there’s no contact between the bodywork and the bar when it’s mounted as you have it. It doesn’t look like there’s a whole lot of room to push it any further forward and away from the grill/bodywork. Have you noticed any paint rubbing? Again I appreciate your help.
jcgcbns22
Caleb
Nova Scotia, Canada
Did you remove the bumper to drill the holes? If so, did you follow any instructions from someone else? Do you have a camera that needed to be relocated?
Brush guard was direct bolt on to factory torx spots and lights mounted directly to the bar. No drilling required. No camera as mid spec (Outer Banks).
jcgcbns22
Caleb
Nova Scotia, Canada
No holes required. Greenlane 9" bar bolts direct and lights directly to the bar via 6 ring clamps. No camera on my Outer Banks spec. Good luck!
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
I was going for a sort-of retro look with the KC lights with stone guards. Pretty simple to attach the bar and wire the lights in to aux switches. Center spot to Aux 2 and outboard driving lights to Aux
Do you have this measurement?
Ford Bronco KC Lights on Capable Bumper 51x6HCqSHcL._AC_SL1500_
DJ1
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
If you have the HD modular bumper like jcgcbns22 then no drilling required and you can just buy a bar from one of the many suppliers. If you have the capable bumper (which is why you are asking I suspect), then yes, you have to drill the bumper to mount anything.
For the MY22 Badlands the HD bumper was no longer standard and when my order got switched from MY21 to MY22 I didn't notice the change.
I didn't follow any instructions, I just started removing the grill and trim to take apart the entire front. I thought I might be able to gain enough access to drill and mount the bar without removing the bumper. It turns out that removing the bumper was easier than taking the grill and trim off. Even with my 11 year old son "helping", it took less than an hour to remove and drill the bumper, then mount the bar and replace the bumper.
DJ1
DJ1
Minnesota
I don't think there is any contact or rubbing. (I hope not, I thought I was pretty careful with the location)
I will take some closeups tomorrow so you can see the clearance all around.
rancid53
Russell
NE Texas
Frontier Prox4
cool to know. I’ll give it a shot this weekend
DJ1
DJ1
Minnesota
Good luck! I am sure there are videos out there on removing the bumper. I don't think you need to remove any trim or the grill. Leaving all that in place helps with the test fitting. Looking back, here is what I would have done:
1) disconnect fog lights, driver side connection (if you have them)
2) pop off plastic covers around tow hooks
3) remove 6 bolts
4) bumper will be loose at this point, be ready for it to fall
5) I seem to remember removing the plates around the tow hooks, maybe that was to make room to mount the bar?
DJ1
DJ1
Minnesota
Ford Bronco KC Lights on Capable Bumper bar 1
Ford Bronco KC Lights on Capable Bumper bar 2
FatRat250
Easton PA
Thanks for all your help and time taking pictures, I really appreciate it. I just ordered the bar - you were a great help!
  • Like
Reactions: DJ1
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
My bar is on order. Should be here this weekend. I'm going with a pair of my Rigid SR-Q lights up front on the bar. I want low profile as to not get in the way of my forward camera.
Ford Bronco KC Lights on Capable Bumper 285232623_586743183004849_4067714821918432532_n
Ford Bronco KC Lights on Capable Bumper 284887611_1135474270398740_2693968344962981474_n
bronco_quig
Kieron
Canada
2021 Bronco, 2020 AMG E53, 1978 Z-28, 1970 C-10
Wow! I can’t believe our Bronco has a twin…
Ford Bronco KC Lights on Capable Bumper 5D6D524F-66A2-4B57-9309-1B39263506D2
Ford Bronco KC Lights on Capable Bumper C8C1C55F-271B-4513-9B52-CC4498DE2BB5
fields_day
San Antonio
2022 4dr Badlands - 2023 2dr Black Diamond
Love it, now you just need the smiley face covers.
MO BRONCO
Fab
Ontario
This is great was hoping there might be a solution for a bush bar and lights on my capable bumper.
Does anyone know if my camera would be blocked if I just run 2 ROUND KC lights on this bar.
