KC Lights on Capable Bumper
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
I was going for a sort-of retro look with the KC lights with stone guards. Pretty simple to attach the bar and wire the lights in to aux switches. Center spot to Aux 2 and outboard driving lights to Aux 1.
Ford Bronco KC Lights on Capable Bumper front corner 2
Ford Bronco KC Lights on Capable Bumper Front KC
Ford Bronco KC Lights on Capable Bumper KC
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
Nice, what bumper bar are the lights mounted to, do you happen to have a link?
I assume you had to drill holes and bolt thru top of capable bumper?
DJ1
DJ1
Minnesota
Here is a link the bar I installed:
https://www.amazon.com/gp/product/B07K8BJG9C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Yes, I drilled the bumper and bolted the bar on. I was going to thread the holes but the bumper is too thin to support the bolts, so thru bolt and nut. I think the bar came with backing plates that have nuts welded on, but I couldn't get those to fit inside the contours of the bumper.
Ford Bronco KC Lights on Capable Bumper KC Bar side
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
I definitely love the retro look of it!
I have been looking for bar that fits my BaseSquatch base bumper, looks like this might work.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
Love it!
Exactly the retro look I want.
Thanks for sharing. 🙂
  • Like
Reactions: DJ1
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
BottleShark
TJ
East Texas
I’m wanting to order this bar and was wondering if I just ran the two outside lights, do you think it would block the camera?
FatRat250
Easton PA
22 Bronco Badlands Squatch Lux Hot Pepper
That looks great and is exactly what I’ve been trying to find for the capable bumper. Two questions, first is the capable bumper solid enough so that you don’t get any wobble. Drives me more crazy when wobbly lights shake when you’re driving along with them on at night. Second question is regarding the front camera, if there was no light mounted in the center do you think the camera would be blocked?
DJ1
DJ1
Minnesota
Seems solid enough to me. I have not tried running down a really bumpy road at night, but no wobble from the bar when you grab and pull.
I can't comment on the camera since I don't have one. If it would help, I can take additional pictures or measure distances for you.
DJ1
DJ1
Minnesota
Teralume ICON 1 on Greenlane Off-road brush bar.
Looks Good! I also bought a Greenlane bar to try but it doesn't fit on the capable bumper. Not enough angle for clearance since the capable bumper sits closer to the grill.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
What is the distance between the light mounting spots center of bolt hole to center of bolt hole? I'm interested in doing this then putting a low profile light bar instead of rounds. This will allow me avoid too much interference with my forward camera. I ordered the bar but it's not gonna be here for a while. I have to decide if I want to nut and bolt it or use a metal nutsert setup for easier removal
TXscooterguy
Dennis
Bedford, TX
1969 Corvette Convertible
Do you think a little time with a bench grinder would have allowed the backing plate that came with it to fit? If anyone builds their own backing plate for the capable bumper, please share the measurements. Thanks.
jcgcbns22
Caleb
Nova Scotia, Canada
The bar is 9 inches and the light are 8.5” but the 6 bar mounts take the lights out far enough to comfortably clear the bumper. I bought their anti-theft hardware too. Had to grind strips of rubber (vs supplied foam) given the weight of the light/bracket combo. Very solid now.
rancid53
Russell
NE Texas
Frontier Prox4
Did you remove the bumper to drill the holes? If so, did you follow any instructions from someone else? Do you have a camera that needed to be relocated?
