KC gravity lights - road noise?
GillyMan
Everglades
Karen
HTown
23’ Bronco
Everglades
Wanting KC Hilites gravity 50". How's the road noise? Love the old school look
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
with the soft top it causes air to flap and increases the noise of it flapping.
ChipM
Chip
Warrenton Va
17 4 Door SD, 00 4 Door SD, 65 Fastback
I have the RTR lights and noise was worse with install....but then installed front hood air deflector and wind noise disappeared.
jrobVT
JR
VT
Discovery 5 - Range Rover P38
Have this setup - no increased road noise - it may or may not be there but with soft top and 35's there is a constant dull roar anyway. certainly a great addition!
josh1121
Josh
Riverside, CA
Nissan Titan XD Diesel 4x4, LandRover Defender 110
I love the look and just installed them. I have the sunrider from Bestop and the lightbar made it MUCH louder. I'm hoping to adjust it tonight, so I will update if there is an improvement.
TRDFurgesson
Bobby
Mid Ohio
www.youtube.com
'22 2dr WT Lux, '22 Mach 1, '92 Toyota 4x4 DLX P/U 3.0L
Stops the buffeting the hardtop produces windows up / front panels off 2dr. No noticeable noise increase and they are amazing in conjuction with the ERA pocket fog lights. KC’s quality is unsurpassed. The harness, lights and mounts are quite impressive.
Ford Bronco KC gravity lights - road noise? IMG_7033
Ford Bronco KC gravity lights - road noise? IMG_6797
LarryBirdsFace
Maine
I have the light bar and it absolutely increases the flapping on the soft top.
I’ve adjusted them every way I can and I can only move the noise further back and above like 45 mph it’s pretty hard to hold a convo. I was definitely expecting some noise, and with the soft top down it’s not that noticeable, but fully latched it flaps like a sheet in a tornado, and that’s the noise not the whirring wind.
looks F’n aces though 😂😂
Ford Bronco KC gravity lights - road noise? IMG_2336
Blakeney
Jeremy
Orem Utah
2023 limited heritage Bronco, Rivian R1S
Awesome set up! I have the limited heritage, what tires are you sporting? Do you have a lift at all? Looks like maybe just a level and wider tires?
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
It's a Wildtrak, so it's still stock. The wheels are KMC Lobo from Discount Tire, tires are Nitto Recon Grapplers (35x12.50x17), also from Discount Tire.
