Kayaks on Soft Top?
LOSTXGOLD
TEO
GARLAND, TX
www.lostxgold.com
2023 Area 51 Base Sasquatch 2.7
Hey y’all!
Just checking to see what y’all are doing about out kayaks in the soft top?
I plan on getting the DV8 soft top roof rack, but until then I am seeing if there’s any other options,
Thanks in advance!
vandyfan
VandyFan
Natick
‘23 Badlands
Interested as well. Was wondering if I need to consider a tow hitch solution, but on top would be better.
Black_Stallion13
Cincinnati
Tacoma
It’s really annoying nobody has STILL created a simple front crossbar for the windshield mounts. That would allow everyone with softops to easily use a regular hitch rack in the back..
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
You can commission a fabricator to create one.
Black_Stallion13
Cincinnati
Tacoma
I mean yeah but I want something with a nice fit and finish on my truck (like rhino rack, Thule, Yakima type stuff). Not into all the aftermarket metalfab companies. Basically I’m being a beggar and a chooser 😆
Durangatan
Marty
Durango, CO
Bronco, A6 Avant, TTRS, SQ5
Having a fab shop create the brackets and making them compatible with a Thule arrow bar would not be rocket science. If you are skilled at design and CAD programs just draw up what you want and taking it to an appropriate shop.
Black_Stallion13
Cincinnati
Tacoma
Black_Stallion13
Cincinnati
Tacoma
That’s true but I wouldn’t want anything on my windshield without a published/tested product weight rating.
LOSTXGOLD
LOSTXGOLD
TEO
GARLAND, TX
www.lostxgold.com
I have the Trektop so those won’t work since the top doesn’t have the full retract mode. I also don’t understand how those cost so much. If they were an aero design or something I could maybe see but they are just square non aerodynamic bars. Seem pretty basic for the price.
Yeah, I was thinking max $200 - But, for that price you might as well get the DV8 soft top roof rack for $1200.
Headsong
I think the weight limit on the mounts above the windshield must give mfrs pause. There's a recent post from a guy who only put like 100+ # up there and broke the mount. A kayak would clearly be ok, but then someone will get the idea to haul that 1/2" plate steel.
BlueBronco
DFW
I made my own. No published/tested product weight rating but I have trust in my welding skillz. It does help that my brother owns a fab shop so I have access to laser cutters, press brakes, etc.
Ford Bronco Kayaks on Soft Top? 1691526038713
As far as the broken windshield mount, I saw that thread as well and it is the only broken mount I have seen reported in 3 years of Bronco deliveries.
BlueBronco
DFW
Nice! How are the rear body mount attachments working out? I wonder if there is enough gap to use that method of attachment with a hardtop.
It is working out just fine for what it was designed for. It wouldn't work with a hardtop as the rear bracket uses the same mounting points. I also didn't intend to use it for anything heavy like a rooftop tent, a couple of plastic kayaks is probably the weight limit.
Ford Bronco Kayaks on Soft Top? 1691528360147
Black_Stallion13
Cincinnati
Tacoma
To me it seems the best design for a windshield mount crossbar would also incorporate the ditch light mounts next to the side view mirrors. I envision like a vertical bar on each side of windshield running along the pillars that attaches to ditch light mounts on the bottom and the windshield mounts up top to spread out the weight across multiple attachment points leading to way less stress on the actual windshield mounts.
Rspayde
North Ga
2022 C/O Black Diamond
https://www.bronco6g.com/forum/threads/bamf-soft-topless-roof-rack.55779/page-6
This is what I went with an it has been pretty great. There when I need it and away un seen when I do not. Have put paddleboards, kayak, lumber, and tents up there without issue.
I also have axe and shovel mounts on the bottom side for securely transporting those items.
Yes you run the risk of getting a bit wet if it rains while transporting but my paddleboard is about three feet wide and acts as an excellent partial roof as needed.
