Just installed Ford Performance Bilstein coilovers
Robs
New hampshire
2023 Black Diamond
I just installed the ford performance coil over kit on my ‘23 non SAS 2 door black diamond. It’s possible the suspension needs to settle a bit but my test drive seemed to result in more noticeable bumps in the road and a bit of nose dive when hitting the brakes that I hadn’t noticed with the Hitachis.
Also my net increase in lift looks like a 1 1/4 inch increase in the front and 1 1/2 inch lift at the rear The set was supposed to deliver a 2” lift as advertised.
Any thoughts?
Charlesbrown165
Chuck
Johnstown, NY
2012 Jeep Wrangler Rubicon 2 Dr Cosmo Blue
Maybe crank up the preload a bit more
mshaunf33
Shaun
Ohio
2023 Bronco
I installed these on my ‘ 23 Black Diamond V6 4 door and only got .75” in the front and 1.75” in the rear… I do think the ride is much better than stock on the street and excellent on rough trails…
Ford Bronco Just installed Ford Performance Bilstein coilovers IMG_2730
lakesinai
Charleston SC
Any thoughts?
A photo would be nice!
JojoReady
North Country
Silverado
I have a 2D 2.3 nonSAS BD and installed the FP Bilsteins earlier this year. I got a full 2 inches front and back. I also added a rear sway bar, which firmly helped stability with reducing nose dive and roll. I later added a track bar relocation bracket which significantly reduced push steer, which was always an issue with the stock setup. I couldn’t be happier with the current setup.
CanadaBaseBronco
Clarke
Canada
2022 Base Bronco
These aren’t adjustable but thanks for your reply
Any thoughts?
Can you fit 35s without removing the crash bars?
Area51BS
Ron
Badlands non SAS 4dr 2.3
How does a rear sway bar reduce nose dive other than added weight in rear?
JimmyZ
Dawsonville, Ga. 30534
Bronco 2023
Which rear sway bar did you install?
Robs
New hampshire
2023 Black Diamond
Not sure. I removed them as a precaution since I knew I was going to get the 35’s either way If concerned I understand there is a slimmer version of after market crash bars that might do the trick
