Just Got Rear Ended Today.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
I’ve had my Bronco for just over a month and just got rear ended by a Chevy pickup today. Ford 1 - Chevy 0.
Oh geez...my heart sank when i read your title. Then turned into a sky grin when i saw your video!
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
cliff notes:
Looks like the tire and the hinge side of the swing gate might be tweaked. Maybe just angle of the pictures.
Southern Girl
1974 Bronco/2024 Wildtrak
When that happened to my son's Jeep, he had to get the tailgate hinges fixed. Maybe it was like that before, but I see a slightly bigger gap at the top than the bottom. I would check the hinges, personally. Also the tire and rim as was suggested. Sorry that happened to you!
For this reason, I want to get a set of big steel bumpers on the front and back of my Bronco. I do not like any of the ones available at present. Hurry up, aftermarket.
da_jokker
Jeep Wrangler JKUR
I'm glad you're Bronco didn't get crushed in like the Chevy, but no way you didn't take on damage. It's unfortunate and hopefully limited to either just the bumper but unfortunately I think your spare took the hit which in turn trashed your rear tailgate.
Luckily those can be replaced easily... Well once parts are available.
MayhemMike
Mercury
Your Bronco will be in the body shop for a minimum of a month. More then likely two months. Body shops like every other business are being held up by part allocation. Being this is a Bronco, it makes it that much more difficult. Good luck.
LVBronco
LVBronco
Ike
Las Vegas, NV
Head on or rear ended? Glad you're okay, that looks brutal. Edit: video shows a bronco sport? Wrong video?
That's not my Bronco. I don't have a sport model.
LVBronco
LVBronco
Ike
Las Vegas, NV
do your spare mount get bent
Everything looks good from initial personal inspection but Im going to take it in to make sure and will update on this thread.
LVBronco
LVBronco
Ike
Las Vegas, NV
Um, your Bronco definitely looks damaged to me. Check the body lines on the hinge side of the tailgate.
I know it appears that way from the video but in person, the gaps look evenly spaced. Regardless, I'm going to take it in and have it professionally inspected.
