OddBall88
OddBall88
Joseph
Ford Bronco
What did you use to fab the 3/4" body lift? I wanted to add a 1/2" or 3/4" myself but have not found anything online. The smallest I could find was 1-1/2".
I ordered some 3/4” x 3” aluminum bar stock and used a hole saw in a drill press to make my own.
OddBall88
OddBall88
Joseph
Ford Bronco
Well after entirely too much time spent, I installed the axxess amp bypass for the B&O system. In the process I figured out you need around 10 open channels off your amp/amps to really do it right. Also the rear speakers and the center speaker isn’t wired into the harness back at the B&O amp, so you’ll need to run your own wires for those. Currently only have a 4 channel amp hooked up, ordered an 8 channel to add to it to get everything powered individually. Will say it way way louder and clearer.
Ford Bronco Joe's BadSquatch Build 554783EE-BBE1-4515-A8C8-75F98D0B1E5E
Also had my S&B air filter arrive today so I tossed it in real quick.
Ford Bronco Joe's BadSquatch Build 0220D5AD-A302-42C5-8C3B-06398D0883CC
rusty603
Russ
NH
2017 Tacoma
Figured I’d start a build thread even if it’s a little late in the game with my build. Start off my Bronco is a 21 Badlands with Sasquatch in velocity blue with the lux package.
This is how it looked in the first week of purchasing it. Also everything besides the upper and lower links have been installed by myself so feel free to ask about if it was difficult or not.
this is how it sits currently
List of current mods
Suspension/Tires
Icon Stage 8 tubular system
BroncBuster braces and bushing
Ford Performance Beadlock rings
BFG KM3 in 315/70R17
JKS Max Tire Clearance Kit
Armor/Bumpers
Next Venture Motorsports rock rails and diff guard
BAMF winch bumper with the Bronco frame brackets moved in around 4” and a Warn Zeon Platinum 10s with Factor 55 ultrahook and AR shackles
JCR Off-road shock skids
Ext Misc
Underground Graphics Hockey Style decal
Texted Black Aeroskin 2 Hood Protector
Etsy Shop Spare Tire Cover
Ford Performance Tube Doors
Ford Mesh Bimini Top
Front Windows tinted to match rear
Ford Front Mudflaps
MBRP Overland Exhaust
Lighting
KC Pro6 Lightbar with BAMF mounts
KC Flex Era 4 on Badass Mounts Swivel and SDHQ A Pillar Mount
Lux Lightening Underbody kit
Interior/Engine Bay
Mountains2Metal Door/Center Console Molle Panels
JCR Off-road Rear Window Molle Panels
Diabolical Inc Slipstream
Ford Soft Molle Panel for Tailgate
Extra Raingler Molle Net I had for a Jeep attached to rear of roll cage
IAG Rear Cupholder and Ez Lift Soft Top Assist System
Mabett Rear Seat Protectors and Center Console Tray
Alpine 10” Sub and Amp
Stickerfab Vinyl Inlays
AR D handle
67 Designs Bronco Rail
KR Off-road ARB Mount with Twin Compressor ARB
DesertDoesIt Seat Jackers and Molle panels
Future/Waiting on Mods
Next Venture Motorsports aluminum skid plates
MetalTech 4x4 Rear Bumper
AR Console Badge
Exhibitions of Speed Trail Sight Delete
Move up to a 37” tire
S&B Dry replacement filter
Maybe an ADV Fiberglass Hardtop
Midland MTX 575 with a Mountains2 Metal mount
And here’s a couple of clips filmed by my wife of me driving the Top of the World trail for your viewing pleasure
Does that show the oem license plate mount? Does the mount need to screw holes into the modular bumper?
OddBall88
OddBall88
Joseph
Ford Bronco
I made sure the dealer didn’t use the OEM mount for the front license plate. I bought the Built Right Industries plate mount and was able to use the screen bolts on the BAMF bumper to reuse that mount.
OddBall88
OddBall88
Joseph
Ford Bronco
Today I tore apart the majority of the trim within the bronco so that I could install the 8 channel amp I ordered. Took advantage of having things apart to clean up some of the wiring I did. Had to run new speaker wires from the center channel to the amp. Also had to ditch the factory sub since that’s where the 8 channel, 10” sub amp and the axxess module are all tucked away. Have to say having each speaker having its own channel from the amp and the adjustability with the axxess makes the system sound soooo much better.
Also forgot to take photos of 75% of the stuff I did and the couple I did take are boring.
OddBall88
OddBall88
Joseph
Ford Bronco
Had to pull the panel off covering the amps to make an adjustment. Snapped a couple photos so you can see what’s going on inside there.
Ford Bronco Joe's BadSquatch Build 83725FB6-CEDB-42F8-ABE8-6A944083ABE9
Ford Bronco Joe's BadSquatch Build A13C331E-E014-40A5-8185-510E39F7EE4F
Can also see the wiring for the KC chase bar.
hey_mikey_
Mikey
Charlotte, NC
2024 4D Black Diamond 10AT, 2022 4D Badlands 7MT (sold)
Is there a place to tap into the rear speakers from the cargo area? Or did you run your new wires up to the head unit?
OddBall88
OddBall88
Joseph
Ford Bronco
I ran new wires. The only speaker connections available from the back are the kicks, 2 outside dash and the sub wires. Pretty easy to add new wires, just snip them near where they plug into the housing and run your new wires across and down behind the trim to the amp location. Unless you’re doing the amp behind the glove box then it might be simpler to tap into behind the radio.
OddBall88
OddBall88
Joseph
Ford Bronco
Added a way to turn off power to the winch and the arb compressor while not in use. Used the BAMF winch controller relocation bracket I had laying around as a way to mount everything.
Ford Bronco Joe's BadSquatch Build 17732C00-BA09-428C-A04C-00CB9A8417EF
Need to clean up the wiring around the fuse box still.
OddBall88
OddBall88
Joseph
Ford Bronco
Spent a few hours this morning and got the wiring cleaned up around the engine. Looks a lot tidier now.
Ford Bronco Joe's BadSquatch Build 7606B8A2-A702-4166-83D7-3AACBA6FD00B
Ford Bronco Joe's BadSquatch Build 825A238F-0EB2-44C7-A4E7-ACA8C05C9661
Ford Bronco Joe's BadSquatch Build D5851437-E1B5-4BBC-BF0E-362831E3AB44
Ford Bronco Joe's BadSquatch Build EDC3B218-F72B-4F1D-B84D-5BD40BF70B83
OddBall88
OddBall88
Joseph
Ford Bronco
Another update, finally got the Next Venture Motorsports belly skids and got them installed, also since MetalTech is taking too long to release their rear bumper I went with the Lod Off-road destroyer bumper. Got both installed right before a long weekend of wheeling. Both are very well made products. But there was a few issues with both. The mounting brackets for the gas tank skid had some sharp edges that I would be worried about rubbing into the tank so I wrapped them with some heavy rubber hose before bolting it all down. On the LoD bumper the swing arm is my only complaint. No matter how tight I got the spindle it would shift so I finally just tack welded it to keep it from moving. Also not really a fan of it latching to the tailgate instead of having a latch on the driver side.
Ford Bronco Joe's BadSquatch Build 12E87E0D-4BC4-4D53-B73C-88A9C3822B8F
Ford Bronco Joe's BadSquatch Build CF501C0F-8EFC-4C83-96FD-1B686809DCCD
So first day of wheeling was with the Gold Country Bronco group on the Deer Valley trail here in Cali.
Ford Bronco Joe's BadSquatch Build 4425753A-D1A7-4BFF-81E3-FC08B0037500
Was a great day wheeling but I quickly realized the extra weight from the bumper was making the rear squat too much so on Saturday, before heading into the Rubicon with some forum members, I moved the rear shock mounting holes up on the rear axle like a forum member also did.
Ford Bronco Joe's BadSquatch Build 47956233-8F37-4A3D-AA29-2267D61FE470
Ford Bronco Joe's BadSquatch Build 93A2C655-1235-4E18-9FFD-DD016D01FF92
Ford Bronco Joe's BadSquatch Build 042D3776-D497-4C8C-8CD0-BA14C6D54EDC
After finishing the day trip on the Rubicon I checked how the belly skids held up and they seemed to have done well but did bend some so that’s a bit of a negative.
Ford Bronco Joe's BadSquatch Build 66E6905F-5F3A-487D-AA77-26F8288731B2
Also side note with the Icon suspension and the 3/4” body light I had rubbing on the DV8 fender liners with 37” tires.
Ford Bronco Joe's BadSquatch Build 37D94C2B-F2FD-48EA-9594-6B198133B19F
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
I don't know, those skids look fine in the pictures.
You know the saying: Good, fast, cheap. You can only pick two.
It's aluminum so it's gonna give some. If it was steel, you would need a bigger motor. ha ha.
OddBall88
OddBall88
Joseph
Ford Bronco
That’s true just seems like this one spot in particular could use a way of being attached or supported to prevent it from flaring out.
Ford Bronco Joe's BadSquatch Build A2A4160C-DF5F-48D9-8F08-5289F9AE1400
NORCALGXP
Sacramento, California
2017 Raptor
This Bronco can wheel it eats up the Rubicon.
Ford Bronco Joe's BadSquatch Build 20221030_111250
OddBall88
OddBall88
Joseph
Ford Bronco
Forgot to add the other day I’d also added the Ford Performance tune. I like how it helps the shift pattern be more crisp while I’m normal drive mode. And seemed to help move the 37s along.
And today I received the nets I order from Raingler Nets and Barriers. And like the other ones I’ve ordered from them they all arrived as high quality as I expected. On the rear I had them custom make the netting separate so that when the Diabolical enclosure is in nothing interferes with each other.
Ford Bronco Joe's BadSquatch Build 4B00A102-E552-4B10-88CC-63D1FCC92303
Ford Bronco Joe's BadSquatch Build FA4BA3CF-9300-44FE-B933-4A9CA3D907C6
