- Josh
- Apr 25, 2022
- 377
- 534
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
JKS 8300 Max Tire Clearance Kit For 2021-2024 Ford Bronco
Link to buy: https://ticklemybronco.com/products/ab-fb-jks-8300-prm
Please use AN5 discount code for additional savings
JKS builds on the capability of the new Ford Bronco with a new Max Tire Clearance Kit designed to optimize the front wheel-well to install larger tires on your stock height or lifted Bronco models. High strength body mount brackets improve clearance while allowing compatibility with stock and aftermarket "stubby" bumpers.
Heavy duty 3/16" steel construction for body mount brackets
High clearance body mount provides a clean look with mid-width and stubby bumpers
Allows for larger tire fitment at all ride heights - Max tire size is dependent on lift height.
Full clearance through wheel travel at 2-4" of lift with 37x12.50 tires (17x9 to 20x9 with 4.5-5.5" backspacing recommended)
Can be installed at any ride height Max tire size dependent on suspension system height
All JKS products are protected by a limited lifetime warranty to ensure they are free from manufacturer defects in material and workmanship so you can go with confidence knowing your JKS parts are covered.
Fitment: 2021-2024 Ford Bronco
