- Josh
- Apr 25, 2022
- 377
- 534
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Rough Country 51052 Tailgate Reinforcement Fits 2021-2024 Ford Bronco 4WD
Available here: https://ticklemybronco.com/products/ab-fb-rou-51052-prm
Use AN5 code for additional savings
Larger wheels and tires can put extra stress on your Bronco’s swing-out rear gate, especially when traveling over uneven terrain. Fortify this crucial area and run a larger spare wheel and tire with Rough Country’s Ford Bronco Tailgate Reinforcement Kit.
This handy bolt-on kit is designed to handle aftermarket tires and wheels with ease. This easy, bolt-on reinforcement plate ties the hinge and spare tire mounting points together for increased strength and rigidity. The result is less strain on your tire carrier and hinges, prolonging the lifespan of your rear swing-out gate.
Rough Country’s Bronco Tailgate Reinforcement Kit works with the factory spare tire carrier or Rough Country aftermarket spare tire carrier kits. Includes a Lifetime Replacement Guarantee!
FEATURES
NOTES - IMPORTANT
Fits up to a 37” tire in combination with the 51053 spare tire relocation bracket.
Fitment: 2021-2024 Ford Bronco 4WD
FEATURES
- Reduces strain on swing-out tailgate.
- Allows for mounting of larger aftermarket tires and wheels.
- Evenly distributes weight across both hinges.
- Easy, bolt-on installation process.
- Durable, solid-steel construction.
- Powder coated black for a long lifespan of good looks.
- Works with factory and Rough Country Spare Tire Carriers.
NOTES - IMPORTANT
