Jerry can mounts on tailgate ideas?
ZapMflash
jason
Downey CA
2021 Bronco Base(ish)
I went with this set up. I didn't want a permanent mount. I haven't taken down the road yet, I got it for a trip I'm taking to Southern Utah in a week or so.
Ford Bronco Jerry can mounts on tailgate ideas? PXL_20240720_004600649
Ford Bronco Jerry can mounts on tailgate ideas? PXL_20240720_004551991
Scoop
Gary
Cuchara, Colorado
2026 Stroppe Edition, '74 Ranger, '76 Trail Rig, '05 F150 FX4
I've driven with mine 80 mph with no problems. Just make sure the ratchet strap is tight!
ZapMflash
jason
Downey CA
I saw your post right after I posted mine. It seems robust enough and I like the ability to take it off and throw it in the garage when I don't need it.
Scoop
Gary
Cuchara, Colorado
Exactly. I don't keep them mounted all the time. Also I swap it easily to my 76 Bronco trail rig when I want to.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Mine requires spare tire delete. Not sure if that's where you're wanting to go. I wouldn't recommend my placement if you still have the factory tail lights. I had to put a door limiter on my tail gate and I've got Oracle flush mount lights.
Edit: I was unable to use the last bit of gas because I must have put some cheap ethanol stuff in it. I refused to pour rusty orange gas into my nice Bronco. Maybe plastic would be the way to go. 🤷‍♂️
Ford Bronco Jerry can mounts on tailgate ideas? MOSMNII
Ford Bronco Jerry can mounts on tailgate ideas? dVAZxsG
Ford Bronco Jerry can mounts on tailgate ideas? RGUVwDq
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
I have the RTR mount - it's off the Bronco right now because I only put it on when I need it, takes just a few minutes to mount or dismount. I use a tailgate limiter to keep from impacting the tail lights on the Bronco - I went with the Mountains2Metal limiter, it's quite good.
I'm very happy with the RTR mount, but as others have said, it's pricey.
Ford Bronco Jerry can mounts on tailgate ideas? IMG_3130
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I've got a similar setup that i use occasionally, not necessarily for jerry cans though - those ratchet strap mounts are great. Try to keep both sides weight balanced though - don't run a full can on one side and an empty on the other. The strap will hold fine, the tire will start to wobble a bit more over bumps though.
gmcoover
gmcoover
Calif
2024 Wildtrack
I wonder if the added weight compromises the spare tire mount and tailgate?
There's probably a hundred different threads on this forum on exactly that topic if you want to search for tailgate reinforcement.
The official capacity for the tailgate at stock is 133lbs, which includes the weight of your spare.
I'll drop this thread here, it's one of the more all-encompassing ones.
https://www.bronco6g.com/forum/thre...lgate-reinforcement-has-performed-best.77308/
ZapMflash
jason
Downey CA
Thank you for the information. I might need to go ahead with a tailgate reinforcement next then to help stabilize the spare with the extra weight. Cheers.
gmcoover
gmcoover
Calif
2024 Wildtrack
Do you have any issues with the loose fitting cans? I am not able to get another turn on the mount even with pliers and the cans fit loosely.
ZapMflash
jason
Downey CA
Mine are fitting tight right now. I bought Vevor brand and they seem good. I have not filled them and driven around yet. I'll know more in a couple weeks when I get back from vacation and give them the full test after 400 miles on the highway and a week of off-road abuse...
