Jerry can mount build.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Forgot to talk about the strut. Be careful because the factory strut allows the tailgate to open too far and the can/mount will break the tail light. You can order a 28" strut off of Amazon. I got the one with 30 lbs of opening force, works perfectly.
Have a link? I'm sure your option is much cheaper. It is a valid point to raise awareness on the potential damage. RTR makes a tailgate limiter that is adjustable.
Eljohno
Eljohno
Illinois
Silverado
28 inch Gas Struts Prop Shock ML2750 28 inch 50 Lb Gas Spring for Truck Cap Tonneau Cover Canopy Hatch Teardrop Camper Floor Hatch Lift Supports, 2 Pcs ARANA https://a.co/d/dphgS9h I'm pretty sure mine are 30 Lb, but when I bring up my order 50 Lb is the lightest listed. I definitely wouldn't go with any more pressure then the 50 Lb one's!
jwysopal
James
Los Angeles
2021 Ford Bronco Black Diamond
I built similar, but for Rotopax, and custom rortopax locking mount as well since I didn’t want to buy one from them for $60. I didn’t take many pics during fab and will have to take more pics of fuel can not mounted but here’s a few ✌
Ford Bronco Jerry can mount build. E9AE256D-93FD-4B8F-BAA2-128294CBAC8A
Ford Bronco Jerry can mount build. 837A3865-428D-4CA0-8631-49B9D97D4C31
Ford Bronco Jerry can mount build. 48CE5888-61FF-4DD2-965C-387BD38C7740
